04-27-2017 02:23 AM - edited 03-17-2019 10:10 AM
I have 2 new links to set up to the DRC and Conakry with a CCME
I have configured but I have errors, here are debugs and config.
No calls possible...
Do you have an idea?
I had already had problems for a connection on this post: https://supportforums.cisco.com/discussion/13202881/conversation-between-2-ccme-internal-extensions
But I have the impression that it is not the same problem
Thanks in advance
04-27-2017 02:50 AM
From the running config of the CME that you shared there are 3 VoIP dial peers which can send the call out to another IP destination, the possible called number patterns are
destination-pattern 237.....
destination-pattern 224.....
destination-pattern 243....
Are you dialing these patterns from the IP phones registered on this CME?
if yes and the call still fails then please share complete "debug ccsip messags" and "debug voice ccapi inout" for a test call that fails. The debugs would be required from both CME's.
Manish
04-27-2017 03:41 AM
Thanks Manish,
Yes, i dial these patterns from the IP phones registered on this CME.
I try to make a "debug voice ccapi inout" tomorrow and come back
237 works for information.
05-04-2017 06:07 AM
In the first debug attached i can see the extension 60 dialing 22401204 and it matches outgoing dial-peer 20 where the translation profile call-conakry strips the 224 and forwards just 01204. When you make this test do you see the call reaching the other CME? I would suggest not stripping the 224 digits on this CME, but let it be routed on the target CME and do the translation there as per the dialplan and test.
Manish
05-05-2017 12:15 AM
Hi Manish,
Thanks again
I confessed that my level cme is not very high ...
Indeed it tries to connect to the remote CME but does not transmit the correct number.
My translation rule should be able to transfer the complete number.
Do you see how I could change it by chance?
thanks a lot
05-05-2017 12:42 AM
If you have the complete extension configured on the target CME then just remove the translation profile call-conakry from dial-peer 20 and test.
dial-peer voice 20 voip
no translation profile call-conakry
Manish
- Do rate helpful posts -
05-11-2017 05:45 AM
Hi Manish,
I have try with no success, I get logs as soon as possible
05-18-2017 12:54 AM
05-04-2017 05:45 AM
09-04-2017 07:10 AM
