Convert enterprise SIP load to 3pcc
mclean.danny
Hi all,
I am having a hard time figuring out how to load a 3rd party load on a 8841. The phone is currently running SIP ver 10.2 enterprise. I am trying to load the 3rd part firmware so we can evaluate a phone SAAS provider. I tried lding from tftp and from CM btu I have a feeling it requires a conversion utility or it might be a no go? Any help would be appreciated. I tried TAC and they have not been helpful so far.
Hello danny,
You can not load 3rd party load in standart 8841.
The cisco guide is writing: " After upgrade to Enteprise image, the phone cannot revert to 3PCC".
If you want use 3PCC firmware you need purchase phone with right part-number. For example:
CP-8811-3PCC-K9=
br Oleksandr
Hello danny,
CP-8811-3PCC-K9=
br Oleksandr
Thanks Olek, I found the same also.I forgot to update the thread. It's Cisco's way of making you buy more hardware I guess.
