04-10-2017 06:50 AM - edited 03-17-2019 10:03 AM
Just wanted to clarify the following.If I set a user account to
Convert LDAP Synchronized User to Local User but leave the account in Ad untouched ( i.e its still there)
Does that mean the account will get re added next cycle time , or it will stay as locak indefinite?
Solved! Go to Solution.
04-10-2017 07:24 AM
Mark, ( long time)
On CUCM 11.0, CUCM will automatically convert the user to LDAP user once the next sync happens. I just verified this now
However on older release it looks like the behavior is different. Refer to this thread here
It looks like the behavior is that the user account will be duplicated.
Please see similar thread here
https://supportforums.cisco.com/discussion/13194241/cucm-ad-sync-and-local-users
04-10-2017 06:51 AM
Meant to say I have checked the SRND etc and I can't find an obvious answer.I assume it stays local indefinite.
04-10-2017 07:24 AM
Mark, ( long time)
04-11-2017 06:53 AM
Interesting , thanks deji appreciate it.
09-06-2018 11:55 AM
This is great information. I have to change my CUCM UserIDs from SAM to UPN on my LDAP Sync'd 11.5 system. SRND isn't clear on how to actually do this, but my best guess would be to:
-Bulk Export User Information
-Change the User ID from SAM to UPN in the CSV
-Convert all LDAP Sync to Local Active users (is there an automated/ 'bulk' process?)
-Upload the Bulk Import file changing User ID from SAM to UPN
-Delete existing LDAP directory
-Change LDAP system settings from SAM to UPN
-Build new LDAP directory
Then, at the first DirSync, CUCM should see the local actives UserID matches LDAP and converts them to LDAP sync.
I have 2k+ users and can't afford to botch this heh.
Rob.
