Converting DX650 firwmare
Siva chinap
Level 5
Level 5
I have DX650 android firmware that I need to convert to SIP firmware. I require assistance with image and conversion steps.
9 Replies 9
AFAIK its a normal cop file as other phone models and the steps are same.
Refer the DX650 sip firmware release guides.
https://software.cisco.com/download/home/284721679/type/282074288/release/10.2(5.215)ES
Response Signature
That guide is for DX70 and DX80. Those are different devices than what the OP asked about.
Response Signature
I got confused with the OP.
Response Signature
AFAIK there is no specific SIP firmware for this particular model of phone. For additional details on how to use it with a SIP service have a look at this post.
Response Signature
Siva chinap
Level 5
Level 5
Please clarify will this https://upgrade.cisco.com
option work for DX650, is there any offline migrate option available @Nithin Eluvathingal @Roger Kallberg
Thats for Dx70 and 80 converting to CE software not applicable for DX650
Response Signature
Is there any last release i can use for migrating firmware to SIP @Nithin Eluvathingal @Roger Kallberg
As I previously wrote I'm not aware of that there ever where any difference in firmware available for this device model.
Response Signature
The conversion from android to CE is available  only for DX70 and 80. There is no conversion or migrations for DX650.
If you need the latest firmware for DX650, down the latest from below link and install the COP on CUCM.
Response Signature
