11-11-2009 10:19 PM - edited 03-15-2019 08:29 PM
Are the voice messages on CUE stored in .wave files, I am in a situation where I need to copy the user voicemessages ( if it's some .wave files) and send them as an attachement to their emails. I don't have acces to CUE and will appreciate if someone can help me verify it.
Appreciate your help on this...
-AB
11-11-2009 11:00 PM
This link has the procedure for backup data that includes voicemail greeting and voice messages,
but I also in a post where,
they have an NM-CUE this wouldn't be an issue because you could just
IMAP into the mailbox and download the messages that way
11-11-2009 11:05 PM
Thank you, Viverma. I can't back the data and restore since I want to copy the files ( is it's .wav) and send it via email to the user. This is because we are switching from CUE to Unity VM system.
Anil
11-11-2009 11:13 PM
You have NM-CUE or AIM-CUE?
11-11-2009 11:21 PM
there's no way to pull these voice-mail recordings off CUE,
You can set up CUE 2.3 for message notification, where it will send a .wav
file to the users e-mail account when a message is left. You integrate this
with your e-mail server... So, if you were to configure this...the user
would have a record of the voice mail messages on hand to save. But right
now...if this isn't configured, there's no way of pulling them off CUE.
Here are your two options:
If you have an AIM-CUE, you can use Message Notification:
http://www.cisco.com/univercd/cc/td/doc/product/voice/unityexp/rel2_3/cue_cl
i/ch_msgno.htm#wp1065257
If you have an NM-CUE, you can use Integrated messaging using IMAP, or
messge notification (same as above).
IMAP:
i/ch_imap.htm
11-12-2009 09:46 AM
Thankyou very much VirVerma. Appreciate your help on this.
