AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
940
Beginner
cor name and list on CME
Hi guys...
I just wondering... do I need to use the same cor name and cor list for each sites for interconnected topology using Fa and Se (ospf/eigrp apply)?
for example,
SiteA(CME)--------SiteB(CME)--------SiteC(CME)
|                  fa
|Se
SiteD(CME)--------SiteE(CME)
                   fa
SiteC unable to call SiteD and SiteE, however SiteA and SiteB has no restriction
SiteA,B and C has COR configured and SiteD and E has no COR configured
Thanks Heaps
Terrence
6 REPLIES 6
Participant
Re: cor name and list on CME
Hi Terrence
Didn't quite understand your requirements.
Do you have routing such that each site has connectivity to other site?
If that is the case, then you point dial-peers to each other sites and control who can call what.
But if you need to configure such that when B calls D or E, it has to go via A and vice versa. When I say this, I mean, B has to send the call setup to A first and A will send to D and E. In that case you need to have cor list configured.
Please clarify your requirement first, then I should be able to help you configuring it
Thank you
- Abu
Highlighted
Beginner
Thanks Abu for your reply, you have always been very helpful to me in this discussion...
basically what I try to accomplish is 1 ext number (1000) from SiteC unable to call SiteD and E and all ext number on siteC unable to call International
I tried to restrict with COR, but when I tested to call from ext (1001) to siteD/E the cisco IP phone display "connected" with a still dial tone then followed by busy tone (dont know what it means)
here is my configuration so far for siteC
SiteC
dial-peer cor custom
  name block-pt
  name permit-pt
  name permit-Int
dial-peer cor list blockDE
  member block-pt
dial-peer cor list permitDE
member permit-pt
dial-peer cor list callInt
member permit-Int
dial-peer voice siteD voip
corlist outgoing permitDE
destination-pattern siteD
session target ipv4:siteD
codec g711ulaw
dial-peer voice siteE voip
destination-pattern siteE
codec g711ulaw
dial-peer voice callInt voip
corlist outgoing callInt
destination-pattern callInt
codec g711ulaw
ephone-dn 1
number 1000
corlist incoming blockDE
ephone-dn 2
number  1001
corlist incoming permitDE
Do I need to configure the COR with the same name and list as SiteC on siteD (such as block-pt, permit-pt) for ext1001 to reach siteD and E?
Thanks again in advance,
Terrence
Participant
Hi Terrence,
Your configuration looks ok.
I guess it is some other issue. If you remove the corlist frome ext 1001 and dial-peer of site DE, can you make the call successfully?
You may want to collect "debug voip ccapi inout" and "debug h225 asn1" for further troubleshooting
Thank you
- abu
Beginner
Hi Abu,
Thanks for your reply,
I will try to do the debug, however, I dont need to configure COR on siteD and E with the same cor name and list for ext 1001 to reach siteD and E?
So, the call should be able to reach siteD and E even though no COR configured on those sites, yes?
and do you know why Cisco IP phone display "connected" with a still dial tone then followed by busy tone?
Participant
Yes, when no cor list is configured, call should reach the other site.
Also, you do not need any cor list on site D or E as you are restricting within SiteC
I'm not sure why you are receiving dial tone at the state of connected. Send me the complete configs from all sites.
thanks
- abu
Beginner
Hi Abu,
thanks again for your reply
can I private message you with the config?
Content for Community-Ad
August's Community Spotlight Awards
