11-23-2010 10:10 AM - edited 03-16-2019 02:04 AM
Some 7941 phones can't find the corporate directory since upgrading to CUCM 8.0.3.10000-8. Phone load is SCCP41.9-0-3S. Forum is loaded with similar problems. I've tried some of the solutions suggested none of which have corrected the problem. It seems that the phones in question are being seen as 'secure' phones because they are picking up the Secure Phone URL's from Enterprise params. I can't see why this is happening all phones are set to use the Standard SCCP non-secure profile. The only difference I can find between 7941 that were working and ones that weren't is the URL pointers. I tried changing the secure Enterprise params to the same as the non secure Enterprise params. The phones picked up the new URL but still couldn't find the corporate directory (host not found). Guess I could try deleting the phone and recreating it but that would leave me not knowing what caused it if it's resolved by this action. Other than that I'm running short on ideas.
I've attached the latest phone log from one of the lost 7941. Seems it's not finding the proper .CTL file?
06-22-2011 04:00 PM
There is one more item to look at that can cause the "Host not found" as well as a loss of ring tones on version 8.6 and later. I am not sure which version this started in but I believe it is with 8.5 that the phones started using the configuration file for the URLs to look up services. It also used the locale file to confirm the certificates. If there is "ANYTHING" that is out of place with the certificates on the servers it can cause this process to fail and the error to occur. In my case during a rehost of my servers I was forced to reload the subscriber to get the cluster working and the database to sync. In the process the servers had created some self signed certificates. My servers originally had third party certs from our internal CA server. When I finally found this thread it got me looking at the phone logs and I could see the cert validation failures. Looking at the certificates there were several for tomcat-trust issued to the server name. The self signed cert was there along with the third party cert. To fix my system it was a matter of deleting the self signed certificates for the services that I had issued third party certificates for. After a reboot all was well (at least so far). The directory now works as well as the custom ring tones have returned.
04-14-2012 03:27 AM
If running on the CUCM 8.x version, because on the "Prepare Cluster for Rollback to pre 8.0 Required Field".
Need to set false, else the Https request wont work
06-26-2012 02:06 AM
Do you know if this new mecanism "Services Provisioning" (set to internal) is phone depending ?
We have a lot of 7940G here and I wanted to know if it should work with this type of phone ? (firmware P0030801SR01)
Thanks you in advance,
Thierry
06-24-2011 07:36 AM
joemar2 fix worked for me. I have the new 8.51 server in a test enviroment, and the FQDN wasn't setup in DNS yet. Changing the name to IP and resetting the services worked. (and then the phone)
04-15-2012 07:21 PM
Hi ma75,
Ya, by default i have use the IP Address instead of the DNS.
But the problem still same.
