03-04-2017 11:42 PM - edited 03-17-2019 09:42 AM
Hello Everybody,
There is an issue appears with me in Corporate Directory service,
All phone registered by one of subscribers can't use Corporate Directory service "host not found" error.
but the phones registered with another subscriber can use it.
Please advice me
Islam
Solved! Go to Solution.
03-05-2017 06:56 AM
usually this indicates that phones are unable to resolve the host of the Publisher (whatever is defined to be your URL for directory under enterprise parameters). Make sure that these phones' DHCP scope includes proper DNS settings.
03-05-2017 06:56 AM
03-08-2017 02:21 AM
yes i think that there is an issue in DNS
it's working now
thanks
03-08-2017 05:30 AM
Glad to hear. Please rate the answers if you found them useful.
03-05-2017 10:27 AM
In addition to Chris' suggestion, this could be an ITL issue. If the Service Provisioning Serive Parameter is set to Internal or Both, any service URL in the format of Application:Cisco/<name of service> will leverage the CallManger Group instead of the publisher, granting the services inherent redundancy. Since all of these services now run over HTTPS in current CUCM releases, it could be that the phone is failing to setup a TLS connection to the primary node in it's CMG.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/116232-technote-sbd-00.html
