Corporate Directory issue in one server
islamahmed
Beginner
Beginner
Hello Everybody,
There is an issue appears with me in Corporate Directory service,
All phone registered by one of subscribers can't use Corporate Directory service  "host not found" error.
but the phones registered with another subscriber can use it.
Please advice me
Islam
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
usually this indicates that phones are unable to resolve the host of the Publisher (whatever is defined to be your URL for directory under enterprise parameters).  Make sure that these phones' DHCP scope includes proper DNS settings.
Chris Deren
Hall of Fame Master
yes i think that there is an issue in DNS
it's working now
thanks
Glad to hear. Please rate the answers if you found them useful.
In addition to Chris' suggestion, this could be an ITL issue. If the Service Provisioning Serive Parameter is set to Internal or Both, any service URL in the format of Application:Cisco/<name of service> will leverage the CallManger Group instead of the publisher, granting the services inherent redundancy. Since all of these services now run over HTTPS in current CUCM releases, it could be that the phone is failing to setup a TLS connection to the primary node in it's CMG.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/116232-technote-sbd-00.html
Recognize Your Peers
