corporate Directory Issue
I can serch Corporate Disrectory from My Cisco IP Phone but I can't Dial Direct from the Corporate Disrectory.
Dial boton shown in Opetion but can't working .
please help it out
Jayesh
17 Replies 17
islam.kamal
Level 10
Level 10
Hello
Is username wirh extension appear in corporate directory , but dial is not work  ?. Can you share with us the
external url (system - enterprise parameters - external url (take a copy and share).
Thank you
please rate if this will  help
Hello
Please Can you use the IP address
https://x.x.x.x:8443/ccmcip/xmldirectory.jsp
try the below also if the above is not working
http://x.x.x.x/CiscoIPServices/LocalizedDirectory/Directories.xml
Thank you
Ayodeji Okanlawon
What is the number displayed in your directory? Is this number the same as the one on your IP phones. I am guessing it is not. You will need to configure xlation pattern to change the corporate directory numbers to extensions on your phone
Sent from Cisco Technical Support Android App
Please rate all useful posts
Ayodeji Okanlawon
Islam, he can access the directory.. Why are you asking him to change the config?
Yes I can access the directory.
the only issue is I cant dial direct from Corporate Directory serch Option.
Hello
You are completely true , but there is no bug on v8.x . So i tried to help him to change the url hostname to IP address , may be it can solve the problem.
Thank you
Ayodeji Okanlawon
Did you read my previous post...please answer my questions..
I think you reuqire Ans for following :
it is 49005 and and it is same in IP Phone
Consider you have a user Mr.X.   His extension is 49005
1) You choose Mr.X on corporate directroy, and when you press 'dial' button...now exactly do you hear / see on screen?
2) What when you directly dial 49005 from your phone. Does the phone rings when u dial '49005' from your phone?
3) Please confirm if your system uses any prefix for dialling numbers.
I dont think this is an issue with corporate directory configuration. This should be a dialplan issue.
Yes I can See
when press to dial butoon no action ..
No Prefix for dialling number
What is your CUCM version? What is your phone model and what is the firmware running on your phones?
"opportunity is a haughty goddess who waste no time with those who are unprepared"
CUCM 8.5.1.10000-26
Phone Modem Cisco 7942
Firmware running on Phone : SIP 42.9-1-1SR1S
Jayesh,
So this is a SIP phone..Does this affect SCCP phones too? Do you have SCCP phones..Can you test them?
