Corporate Directory login
Abdullah Hashim
HI to all
in our company if the user need to search in the Corporate Directory  every time he must registration with the Required Field and Password
We upgraded our CUCM from Call Manager 4.1(3) to 8.6
before we  search in the directory with out Login.
Now when you open the corporate directory on the phone  every time i must login with my ID and PW
we don't  Integration  any external LADP or  Microsoft AD with our CUCM (Local End Users)
Is there any solution for this Case ?
Thank you all for Help
5 Replies 5
Chris Deren
Corporate directory does not require login, personal directory does, are you sure you are using corporate and not personal directory?
Chris
Sorry I mean personal directory.
Hi.
Since is not possible to avoid userid and pin request for personal directory, there are some workaround that you can find in this post https://supportforums.cisco.com/thread/2102038 or this doc https://supportforums.cisco.com/docs/DOC-1385
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hello Carlo,
Could you please update the posts ? These are removed.
Alternatively, please post the answer itself.
Much obliged.
Kind regards,
Alex
You do realise that this post is more than 10 years old? Apart from that as you’re a Cisco employee you have other internal resources to seek out information. This community is not the appropriate place for you to ask questions.
Response Signature
