Beginner
corporate directory not showing
Some phones does not showing the corporate directory . These phones are registred on sub ,at the same time other phones which is registred on the  sub can see the  directory .
directory is local .
http://192.168.5.10:8080/ccmcip/xmldirectory.jsp
https://192.168.5.10:8080/ccmcip/xmldirectory.jsp
cucm 10.x
6 REPLIES 6
Enthusiast
Re: corporate directory not showing
Are they different model phones?
Can you capture logs for the device? Also, the phone should have a web interface, if you check the status messages, make sure the device is authenticated and has a good ITL / CTL file.
Highlighted
HTTPS will fail unless you use a proper DNS FQDN; certificates do not include the IP address in the CN or SAN.
Do the ITL thumbprints match between a working and non-working phone?
Does “show itl” work from the TFTP nodes?
Are the TVS server certificates not expired and present in the ITL?
Beginner
The problem is intermittent . So I think it might not be related with certificate .The certificates are valid ?
Could you explain how can I do this
You did not mention this was intermittent on the same phone. If that's the case you would want to pull either console logs from the phone, a packet capture, or both to understand what's going on.
You can read more about ITL operations here: https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/116232-technote-sbd-00.html
Beginner
hi,
is there a way to move from the sub to. Pub without restarting the Sub to confirm the problem is with the phones which registered to the sub.
Rising star
Yes, you can move phone registration from CUCM Sub to Pub without restarting Sub. Follow this procedure:
1. Make CUCM Pub as primary and CUCM Sub as secondary under Cisco Unified CM Group.
2. Click Save and Reset Cisco Unified CM Group
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Content for Community-Ad
August's Community Spotlight Awards
