01-17-2013 03:34 AM - edited 03-16-2019 03:13 PM
I've a cucm 8.5 (it's a cluster with two devices on VmWare machine). that works well.
The only problem is related to a cacorporate directory:
on the CIPC it works well, but on the cisco ipphones when I press the relatied key, oh the display appers " host not found"
I've checked the dns, and the configuration and for me it's all ok.
Can you you have any suggestion to help me?
Thanks in advance
giancarlo
01-17-2013 05:05 AM
CIPC uses the non-SSL URLs, those listed in ent params as 'Directories URL'.
Phones will generally use the SSL ones - listed below that as Secure Directories URL.
Check that the name for the SSL one is correct.
If it is, try restarting the TVS service on CUCM and then reset a phone and try again.
Aaron
01-17-2013 03:13 PM
Hi Aaron, thanks for help.
regarding the problem I've followed your indication but I dont know how verify the url.
in my cucm I've the following url
Phone URL Parameters
URL Authentication http://172.16.2.240:8080/ccmcip/authenticate.jsp
URL Directories http://172.16.2.240:8080/ccmcip/xmldirectory.jsp
URL Idle
URL Idle Time 0
URL Information http://172.16.2.240:8080/ccmcip/GetTelecasterHelpText.jsp
URL Messages
IP Phone Proxy Address
URL Services http://172.16.2.240:8080/ccmcip/getservicesmenu.jsp
Secured Phone URL Parameters
Secured Authentication URL https://172.16.2.240:8443/ccmcip/authenticate.jsp
Secured Directory URL https://172.16.2.240:8443/ccmcip/xmldirectory.jsp
Secured Idle URL
Secured Information URL https://172.16.2.240:8443/ccmcip/GetTelecasterHelpText.jsp
Secured Messages URL
Secured Services URL https://172.16.2.240:8443/ccmcip/getservicesmenu.jsp
Thanks in advance
giancarlo
01-17-2013 11:38 PM
Basically to verify it you can browse to it (idieally with Chrome or Firefox as IE will hide often hide xml).
To be honest they look correct to me, assuming 172.16.2.240 is a CUCM server? I would:
1) Check an affected phone 'status messages' log in the settings. Look for messages saying 'Trust List Update Failed' (failed)... or 'Trust List Updated' (good). If it says failed you may have some larger problems!
2) Go into CUCM serviceability, Network Services Control Centre and restart the 'Trust Verification Service'. Restart a phone and test it again.
Aaron
01-18-2013 12:16 AM
Can you try deleting ITL file from one of the affected phone and see if that makes any difference...
01-18-2013 01:05 AM
Hi Giancarlo,
Could you please go to Device >> Device Settings >> Phone Services and check if "Corporate Directory" is listed and if the "Enterprise Subscription" option set to true?
If it is, please take an screenshot of its configuration so we can check it; it should look like the one above:
espereir
01-18-2013 03:37 AM
In CUCM, system>server...what do you have is it a hostname or ip address?
If you are using a hostname there, then do you have a DNS server configured for the phones..Can you send the configuration of one of the affected phones here using the method below
tftp -i 10.1.1.1 get SEP0000DEADBEEF.cnf.xml
change 10.1.1.1 to your cucm ip address, and sep00000..to one of the phone mac address.
To enable tftp client do this
open Control Panel > Programs and Features > click Turn Windows features on or off in left side > enable Client TFTP then click in OK
Please attach the phone config file here
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
