Highlighted
Beginner
Corporate Directory showing wrong extension
I have a user that's showing the wrong extension in the corporate directory (via phone Directories, Corporate Directory).  We're AD synchronized, so I know the wrong number was coming from AD.  But our AD folks fixed the number a few hours ago. However I confirmed (via the End User page) that it still lists the wrong extension.
Do you know how long AD to CUCM syncronization takes?  Is there a way to force a sync?
4 ACCEPTED SOLUTIONS
Highlighted
Rising star
The default replication is 6 hours I believe. You can run a manual sync to force the update.
Yosh
HTH Regards, Yosh
Highlighted
Participant
LDAP Synch replication is set in the LDAP deirectory page (Sysyem---LDAP----Directory). From there you can perform a manual sync and change the timer.
Gareth
Highlighted
Hall of Fame Community Legend
Hi Bill,
I just thought I would add a link to the great tips from Yosh and Gareth (+5)
You can now force a manual sync in order to synchronize the users
System> Ldap> Ldap Directory
and open the
Directory Integration Field
At the             bottom, click the Perform Full Sync Now button.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080a57c4c.shtml#sync
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
Highlighted
Please go to LDAP directory and click perfom full sync.
http://blog.ipexpert.com/2010/04/28/cucm-and-active-directory-integration/
Above is the wonderfull link explains the entire integration process.
Nirmal
Pls rate helpful posts.
7 REPLIES 7
Highlighted
Rising star
Yosh
HTH Regards, Yosh
Highlighted
Participant
Gareth
Highlighted
Hi Bill,
and open the
Cheers!
Rob
"Talk about a dream
- Springsteen
Highlighted
Thanks all (+5), but I'm missing the Perform Full Sync Now button. This is System version: 8.5.1.11900-21
Highlighted
You're in the LDAP system submenu... Go down one more to the LDAP directory submenu.
Gareth
Highlighted
That was it, thanks
Highlighted
Nirmal
Content for Community-Ad
