12-12-2014 06:47 AM - edited 03-17-2019 01:18 AM
I have to virtual machine 1 Pub and 1 Sub on 2 UCS servers.
I have cucm10.5 and when I pres the Corporate Phonephone on the device I receive the Connection failed. Any ideas.
12-15-2014 06:13 AM
After activate the service the same problem.
12-15-2014 06:36 AM
Can you please attach console logs of ip phone?
Carlo
12-15-2014 06:40 AM
provision_status_flag = 13
**** Wait Provison ****
provision_task 3750 tftp_server_ip: 10.217.196.4
uptime: 0days,04:11:08 : CTLSEP442B031992E3.tlv updating
uptime: 0days,04:11:08 : CTLSEP442B031992E3.tlv not found in 10.217.196.4
uptime: 0days,04:11:08 : ITLSEP442B031992E3.tlv updating
uptime: 0days,04:11:08 : ITLSEP442B031992E3.tlv (HTTP)
uptime: 0days,04:11:08 : ITLSEP442B031992E3.tlv updated successfully
Process Trust File /CFG/VC_ITLSEP442B031992E3.tlv successfully
uptime: 0days,04:11:08 : ITL installed
uptime: 0days,04:11:08 : SEP442B031992E3.cnf.xml.sgn (HTTP)
Authenticating configuration file SEP442B031992E3.cnf.xml.sgn successfully
uptime: 0days,04:11:08 : Authenticating configuration file SEP442B031992E3.cnf.xml.sgn s
ccessfully
iptables: rule (does a matching rule exist in that chain?)
ip6tables: rule (does a matching rule exist in that chain?)
Dec 15 14:11:10 kernel: eth0: no IPv6 routers present
uptime: 0days,04:11:12 : Loads name : SCCP6945.9-4-1-3.loads
Authenticating SCCP6945.9-4-1-3.loads file successfully.
download_configuration_process(2866) : upgrade loads SCCP6945.9-4-1-3 fail
ffs_readfile 96 fd == ERROR (/CFG/ealarm.data)
00:04:11:23.292 - E/AMMU: Checking Protocol: Device=SCCP. Config=SCCP (OK)
00:04:11:23.326 - E/PXMAN: pxman_set_g3_tone(). g3_tone rtl_alerting cfg ok.
00:04:11:23.326 - E/PXMAN: pxman_set_g3_tone(). g3_tone rtl_reorder cfg ok.
00:04:11:23.328 - E/PXMAN: pxman_set_g3_tone(). g3_tone rtl_line_busy cfg ok.
00:04:11:23.328 - E/PXMAN: pxman_set_g3_tone(). g3_tone rtl_outside_dial cfg ok.
00:04:11:23.328 - E/PXMAN: pxman_set_g3_tone(). g3_tone rtl_inside_dial cfg ok.
00:04:11:23.330 - E/PXMAN: pxman_set_g3_tone(). g3_tone rtl_recorder_warning cfg ok.
00:04:11:23.330 - E/PXMAN: pxman_set_g3_tone(). g3_tone rtl_mwi cfg ok.
00:04:11:23.332 - E/PXMAN: pxman_set_g3_tone(). g3_tone rtl_monitor_warning cfg ok.
00:04:11:23.332 - E/PXMAN: pxman_set_g3_tone(). g3_tone rtl_secure_warning cfg ok.
00:04:11:23.334 - E/PXMAN: pxman_set_g3_tone(). g3_tone rtl_nonsecure_warning cfg ok.
00:04:11:23.734 - E/ACCU: SCCP REG OK[(-1,0), (-1,0)]
00:04:11:23.740 - E/ACCU: SCCP REG OK[(0,0), (-1,0)]
00:04:11:23.814 - E/ACCU: SCCP REG OK[(0,0), (1,0)]
00:04:12:03.048 - E/xml_service_provisioning_internal_proc(8642) Not support Application:
isco/MissedCalls
00:04:12:03.050 - E/xml_service_provisioning_internal_proc(8642) Not support Application:
isco/ReceivedCalls
00:04:12:03.052 - E/xml_service_provisioning_internal_proc(8642) Not support Application:
isco/PlacedCalls
00:04:12:03.678 - E/SECLIB: Sec SSL Connection - Handshake failed.
00:04:12:04.682 - E/SECLIB: Sec SSL Connection - invalid session handle.
00:04:12:04.682 - E/xml_service_http_open_connect_v4 (4657): secSSLIsConnected(10.217.196
4:8443) -2!
00:04:12:04.684 - E/SECLIB: Sec SSL Close Connection - invalid session handle.
00:04:12:04.684 - E/xml_http_callback(9155) download update fail!
00:04:12:55.400 - E/xml_service_provisioning_internal_proc(8642) Not support Application:
isco/MissedCalls
00:04:12:55.402 - E/xml_service_provisioning_internal_proc(8642) Not support Application:
isco/ReceivedCalls
00:04:12:55.404 - E/xml_service_provisioning_internal_proc(8642) Not support Application:
isco/PlacedCalls
00:04:12:56.062 - E/SECLIB: Sec SSL Connection - Handshake failed.
00:04:12:57.066 - E/SECLIB: Sec SSL Connection - invalid session handle.
00:04:12:57.066 - E/xml_service_http_open_connect_v4 (4657): secSSLIsConnected(10.217.196
4:8443) -2!
00:04:12:57.068 - E/SECLIB: Sec SSL Close Connection - invalid session handle.
00:04:12:57.068 - E/xml_http_callback(9155) download update fail!
00:04:12:59.790 - E/xml_service_provisioning_internal_proc(8642) Not support Application:
isco/MissedCalls
00:04:12:59.792 - E/xml_service_provisioning_internal_proc(8642) Not support Application:
isco/ReceivedCalls
isco/PlacedCalls
00:04:13:00.512 - E/SECLIB: Sec SSL Connection - Handshake failed.
00:04:13:01.514 - E/SECLIB: Sec SSL Connection - invalid session handle.
00:04:13:01.516 - E/xml_service_http_open_connect_v4 (4657): secSSLIsConnected(10.217.196
4:8443) -2!
00:04:13:01.516 - E/SECLIB: Sec SSL Close Connection - invalid session handle.
00:04:13:01.516 - E/xml_http_callback(9155) download update fail!
00:04:15:45.330 - E/DLM: No DNS server response!
00:04:15:45.334 - E/DLM: No DNS server response!
00:04:15:45.334 - E/xml_service_dns_lookup (4293): unknown host=<10.217.196.4>
00:04:15:45.336 - E/xml_http_callback(9155) download update fail!
12-15-2014 06:55 AM
Hi.
Have you tried to regenerate certificates mentioned above?
Is the phone time synchr with CUCM?
Let me know
Carlo
12-15-2014 07:03 AM
The time is synchronize with cucm, I check under Operating System Administration System Status. If I will regenerate certificate i will not have problem with the cluster because this is an productions environment with 3.000 devices.
Thanks for replay
12-16-2014 11:09 PM
I regenerate Tomcat/vts then restart tomcat/vts database and nothing. After I reset the phone still receiving message connection failed.
01-08-2015 07:23 AM
ciscocm.enable_sslv3-v1.0.cop.sgn
01-13-2015 03:07 AM
Hey guys,
After I install the SCCP6945.9-3-3-2-SR1 firmware and restart sftp and the phones work both of them ( personal and corporate phone book).
01-13-2015 03:16 AM
Hi.
Very good news!
Older version alway work better than newer :)
5 stars to you
Cheers
Carlo
