Corporet directory between two cluster
mkhriesa
dear,
we have a cucm 10.5 installed on cluster 1....we just installed another cluster (cluster 2) with cucm 10.5 , we configured intercluster trunk between them.
my question is : when we open a corporate directory from cluster two we dont see any user from cluster one , is there anyway to allow ipphones on cluster two to see the corporate directory on cluster 1?
THanks
5 Replies 5
Rajan
You could try changing the URL for corporate directory to the one with Cluster 1 IP address.
from where?
Deepak Rawat
Well, I think it is possbile if you have same AD integration for both the CM clusters. Since, you just want the users on Cluster 2 to see the information of users on  cluster 1,then just pull those users as well which are sitting on cluster 1 and you should be good to go.
Alternatively you can also present the Corprate Directory service as XML that you would need to develop containing users information from both the clusters and host it on a web server.
You can also refer to below link:
https://supportforums.cisco.com/discussion/10601851/how-merge-directories-2-cucm-connected-ict
Deepak
- Rate Helpful Posts -
Dear,
 we dont use AD, any idea?
You'll need to build custom directories to achieve that.
java
if this helps, please rate
