Hi There,
I am installing CUCM 8.0 on VM ware 9.0, I am seeing this errro once i have given the image from the same laptop.
Could not find kernal image : linux
boot:
Hardware details which I have given in VMWARE:
HDD Size - 40G
Memory - 1 G
Thanks & regards,
Bala
Solved! Go to Solution.
Hi Bala,
Please use a bootable image and it should work fine.
Harmit.
Hi Bala,
Please refer to the system requirements for running CUCM in a virtualized environment:
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements
http://docwiki.cisco.com/wiki/Unified_Communications_in_a_Virtualized_Environment
Here are the system requirements for CUCM 8.0:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_0_2/install/cmins802.html#wp584395
HTH.
Harmit.
Thank you..
My pleasure Bala, good luck! :-)
Harmit.
Hi Harmit,
I have the config and spaces as mentioned in the above links. But Still getting the same error. Is there any other step to fix this issue?
Bala
Hi Bala,
The specs you mentioned are not enough:
HDD Size - 40G
Memory - 1 G
Double both of them and it should hopefully go through fine. Refer to the table at the bottom about the memory and disk requirements for different server models just to give you an idea:
HTH.
Harmit.
Hi Harmit,
Yeha, I have chnaged to 80G for HDD and and 1.5GB for RAM, Still i am getting the same error.
Also for your information that, Same ISO image is working fine on another Virtual machine that is PUB01.
Am trying to install PUB02. I am getting the error in the subject,,
Thanks!!
Bala
Hi Bala,
That error normally points to a bad image. Try deleting the VM and creating it again with 80GB HDD and 2GB RAM. Make sure you have enough resources on the machine where you are trying to install this VM.
Harmit.
Hi Bala,
Harmit.
Hi Harmit,
I am happy to inform that, it worked finally, Thanks for your time and suggestion..Follwing steps have been taken..
1.Increased the RAM to 4GB
2.Created a bootable ISO file.
Thanks & regards,
Bala
Hi Bala,
Excellent, glad to know it's working now :-)
Harmit.
