Could not register mobile communicator with CM7
sirivoravith
how to register mobile commnicaotr on symbian,nokia E61, to callmanager 7? i have tried to check several thing, document guide but until now no resouce to find, do anyone had a chance to use this before, how to config?
Cisco Unified Mobility that is built into UCM consists of Mobile Connect (aka Single Number Reach) and Mobile Voice Access (aka DISA).
The Nokia E61 can also register as a SCCP phone when connected on a WiFi network if you purchase the license from Nokia.
Mobile Communicator requires a CUMA server.
gogasca
Level 10
Level 10
In order to Install and use CUMC (Mobile Communicator) you will need to setup a CUMA (Mobile Advantage) server
http://www.cisco.com/en/US/products/ps7271/products_user_guide_list.html
so what 's about mobility that CM6-7 support , did not mobile communicator also? cause i seen device in ipphone,
in case if we need to buy mobility advantage , do we have to buy software and license also.
anyway thank you in advance
