Beginner
Couldn't access GUI of CUCM some times
I'm facing a weird problem where I couldn't access the GUI of CUCM sometimes, without any apparent reason,I have to reload CUCM VM to get access to it, by using the SAME PASSWORD
what could be the reason guys, and how to solve it ?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Highlighted
Beginner
Re: Couldn't access GUI of CUCM some times
hello,
There is no issue with CUCM and connectivity, after restarting tomcat service, it works sometimes sometimes not... To solve this I just created another username with admin privileges .. and that's it .. it looks like a bug with the default admin created :/
3 REPLIES 3
Obvious question,
Are you able to ping the IP address of your Call Manager when you face this issue?  You may find the useful link useful:
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118927-technote-cucm-00.html
Additionaly, you may try to restart the Tomcat service from the CLI.
G
Please always Rate Helpful Posts and/or Mark Solutions as Accepted
Rising star
Instead of a reboot of the whole server, try a restart of Tomcat service from CLI.
Also, do a continuous ping to CUCM and see if there are any packet drops.
Simultaneously check the RTMT for any CPU or memory spikes in CUCM.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Highlighted
Beginner
hello,
Content for Community-Ad
July's Community Spotlight Awards
