cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
12
Respostas
CP-3905 + asterisk?
alextelkin
Good day.
Is there any way to make cisco 3905 work with asterisk?
Cant find any config examples.
Thank you.
12 RESPOSTAS 12
alextelkin
If some1 will have same problem:
Config file from 7911 works just fine.
Remember to change "transportLayerProtocol" to 2 if you dont have tcp support enabled.
SIP
cisco
cisco
D-M-YA
UTC Standard/Daylight Time
2000
5060
5061
10.10.1.1
true
true
x--serviceuri-cfwdall
x-cisco-serviceuri-pickup
x-cisco-serviceuri-opickup
x-cisco-serviceuri-gpickup
x-cisco-serviceuri-meetme
x-cisco-serviceuri-abbrdial
false
true
true
true
6
3600
120
4000
70
false
None
false
true
false
false
101
avt
false
false
false
false
16384
32766
button="1">
9
Asterisk
10.10.1.1
5060
1109
Francisco
1000
false
true
false
false
true
button="2">
21
speed dial name goes here
speed dial actual number goes in here
5060
184
dialplan.xml
true
SIP11.8-4-1SR1S
false
false
00:00
00:00
00:00
1143565489-a3cbf294-7526-4c29-8791-c4fce4ce4c37
New_Zealand
New_Zealand
5.0(2)
http://www/ipphone/authenticate.php
http://www/ipphone/directory.xml
http://www/ipphone/GetTelecasterHelpText.jsp
proxy:3128
http://www/ipphone/services.xml
96
false
This is great, but guys, my device even doesn't ask for an TFTP.
How did you make it ask for a file from tftp server ?
Previous models are asking this by default, but this one requests IP address, and goes to 'unprovisioned'.
I tried 'next-server' option without a 'filename', just to loook what files it's interesetd in, but still all I got is silence after an IP renewal.
Upd: Got it. Now its able to register on the *, and I'm make exactly one call, after that it goes to 'registering' loop and doesn't answer anymore. And doesn't ring.
Upd2: after removing the section completely now it works just fine, only the issue with the displayed time (synced from NTP, but GMT+0 instead of GMT+6) remains.
Can you explain the procedure ?
which file is required ?
philippe
This problem with TimeZone that only showed GMT +0 also happened to me, but the problem is solved in latest firmware updates.
In my case, just updated CP-3905 FW from 9.2.1.0 to 9.4.1 SR2-2 and problem solved, TimeZone just works fine now.
hrosales
Helo Alendarder
Do you have a procedure to configure cisco 3905 work with asterisk ?
thanks
hsoto2510
Hi Alex,
do you happen to have a procedure fore this? I'm currently trying to achieve the same goal. Regards!
Hi! I manage to make 15 3905 phones to work with this config file.
Hope it works for you!
Hi Kurt,
Thanks very much, I had the same problem with CP 3905, have edited the file now every thing works. I appreciate you support.
JM
Do need a firmware of 3905 to work with asterisk?
Hi, thank ou for sharing the config file, now I would like to know how doi I send the file to the Phone, I have searched all around manuals and forum, but no clue, is there any reference or small explanation available?
Thank you in advance.
Please, how to send the file to the phone???
Thanks.
