10-11-2011 12:27 PM - edited 03-16-2019 07:26 AM
the IP Phone CP-3905 support Extension Mobility feature?
In the Q&A appears that the CP-3911 does not support Extension Mobility feature but I dont see if is supported for 3905
Alejandro
Solved! Go to Solution.
10-12-2011 11:52 AM
Hi Alejandro,
In this comparison matrix you can check out that cp-3905 does not support extension mobility feature.
Enjoy it!
Silvia
10-12-2011 11:52 AM
Hi Alejandro,
Enjoy it!
Silvia
10-12-2011 11:55 AM
Thanks Silvia
