08-26-2017 10:04 AM - edited 03-17-2019 11:04 AM
I have a Cisco CP-7821 model POE IP phone, I wanted to use that phone to get registered with SIP.
I have performed the following steps for that
1) Downloaded the latest Cisco IP Phone Firmware sip78xx.11-5-1-18
2) Downloaded third Party TFTP Server SolarWinds TFTP Server 10.9.1.33
3) have placed the required files in the TFTP root directory.
I am getting an error as unable to download ITLFile.tlv, ctl.tlv and ITL.tlv files.
Please find the attached configuration file.
05-23-2019 10:01 AM
kern2.78xx.11-2-3MSR1-1.sbn
rootfs2.78xx.11-2-3MSR1-1.sbn
sboot2.78xx.11-2-3MSR1-1.sbn
sip78xx.11-2-3MSR1-1.loads
These are images for the MPP variant (https://www.cisco.com/c/en/us/products/collaboration-endpoints/ip-phones/multiplatform-firmware.html) .
What's the current software version on your phone?
09-23-2017 08:01 AM
Based on the info in your post you are using a "enterprise" phone meant to register against CUCM, CME or HCS. You can quickly verify by checking the SKU on the back of the phone. If it misses 3PCC in the SKU name (e.g. CP-7841-3PCC-K9=) then the phone isn't properly registring against Asterisk/Freeswitch/Broadsoft/...
If it is a Cisco MPP phone (with a SKU mentioned above containing 3PCC) then we support these configurations and have a full list of features including ACD, Voicemail, Group Pickup, BLF, etc,..
If you go to the MPP (multi platform phones) section on CCO you can find the admin guides (including examples). MPP firmware is available on CCO (current load is: 78xx.11.0.1.MPP-477 or 88xx.11.0.1.MPP-477).
The phones can't switch from an enterprise firmware to a MPP load.
09-04-2018 08:10 AM
just a quick question… Did the support change? I have a CP-7821-K9 that I would really like to connect via SIP to third party callmanager. Is that possible or can I only connect it to a cisco CUCM?
09-04-2018 08:56 AM
09-04-2018 03:12 PM
09-05-2018 01:41 AM
Hi Leo,
The question was did the support change (so is it supported and works properly).
Enterprise phones from the 78xx/88xx series are not supported on Asterisks. Could you reverse engineer some parts of the config to get a phone to register on Asterisk and get very basic telephony, yes you could. The challenge is this is not supported, documented and has 0% guaranty it will work or keeps working.
Enterprise phones use SIP signalling but we have extra extensions that create the full experience with all the features of CallManager (CUCM). Every firmware update will potentially break the operation of the phone and like I said their is no proper way to get certain elements configured on the enterprise phones without a CUCM.
Phones running MPP firmware are the only phones we currently produce and support for 3rd party call control (that includes Broadsoft which has been acquired by Cisco last year).
Running this firmware you have normal access to all the features using either the WebUI, PhoneUI or XML and is fully supported by TAC
So for now CUCM and HCS require a 78xx/88xx running enterprise firmware. 3rd party call control requires mpp firmware for the 68xx/78xx/88xx series
09-05-2018 02:04 AM - edited 09-05-2018 02:05 AM
Well thanks for the answer. At the end of the day the phones should only register to my LANCOM Callmanager and to basic telephony. We don't need any "fancy" stuff for the moment just receive and place calls ;)
Is that possible or not? ;)
If not is there a possibilty to get a CUCM license (like a DEMO) for at least 3 months?
09-05-2018 03:51 AM
09-05-2018 04:13 AM
So what i got from this is:
I can upload a config file and make the phone registering itself with my CM and also I'm able to place and receive calls. Thats all I wanted to know ;) so I don't need to change the firmware etc. "just" configuring the XML is enough?
09-05-2018 04:38 AM
09-11-2018 11:11 PM - edited 09-11-2018 11:11 PM
Thanks a lot Leo Laohoo for your support.
Got my Cisco phones up and running with doing simple calls between each other and out into the normal network via SIPGATE which is totally fine for my scenario right now.
Kind regards
Hannes
09-11-2018 11:36 PM
08-18-2019 06:47 PM
Hannes,
I've currently run into the same issue and was hoping there was a .xml template ( minus passwords / IPs ) that I could clone and revise. If I could have it sent to the email acct below that would be gr8.
tntfitness44@gmail.com
08-19-2019 12:01 AM
