cp-7900 series phone ip missing
k2931
If you reset the phone by software and reboot, the ip setting will be lost. TFTP is set as it is.
The version in use
CUCM 11.5.1.17900-52
IP Phone (Firmware SCCPXX.9- 4-2SR3-1S)
Yun Ho Ko
I have the same problem.
When the IP phone is reset, the IP address, Default-gateway, and Subnet mask settings are lost.
So if you set the IP again and reset it again, it will happen the same.
The IP phone model is the 79XX series.
Thank you
