CP-7942G: loading stucks on SPEAKER LED
posuvaluk
Hi to all!
I have 9 phones 7942G in same state while loading starts: first all LEDs are ON, then OFF. Next, the Headset, Microphone mute and Speaker indicators flash once in sequence and Speaker indicator remains ON. And there is no other indications...
Two phones turned out to be reset by the reset procedure to factory settings and flashed with the most recent firmware, but the rest cannot be reset.
Can You help me with my problem?
Thanks in advance!
Remaining phones might have some hardware fault. Since these are EOL devices better u might think of replacement phones.
Response Signature
Very sad... I was hoping it wasn't a hardware problem...
Thanks for reply!
