CP 7965 change locale
kidatsuda
Hi all!
I have CME v10 and CP 7965g connected as SCCP phone and want change phone locale to russian .
I upgrade phone firmware, set time zone in telephony-service, recreate cnf files  and restart phone. In /its/vrf1/ directory i have xml file SEP<SAME_PHONE_MAC>.cnf.xml   with  already configured russian locale.
<dateTimeSetting>
<dateTemplate>D/M/Y</dateTemplate>
<timeZone>Russian Standard/Daylight Time</timeZone>
</dateTimeSetting>
<callManagerGroup>
<members>
<member  priority="0">
<callManager>
<ports>
<ethernetPhonePort>2000</ethernetPhonePort>
</ports>
<processNodeName> < Gateway IP address > </processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
</devicePool>
<commonProfile>
<callLogBlfEnabled>3</callLogBlfEnabled>
</commonProfile>
<loadInformation>SCCP45.9-4-2-1S</loadInformation>
<userLocale>
<name>Russian_Russia</name>
<langCode>ru_RU</langCode>
<winCharSet>utf-8</winCharSet>
</userLocale><networkLocale>Russian_Federation</networkLocale>
<networkLocaleInfo>
<name>Russian_Federation</name>
</networkLocaleInfo>
But on phone display in locale configuration i have
User Locale : English_United_States
User Locale Char Set : ASCII
How can i change locale on phone?
7 Replies 7
Sreekanth Narayanan
You are seeing En US on the Locale configuration. But what about the softkeys and other menu options? Does that appear in Russian? Or is that also in English?
Thanks for your answer
soft keys also in English
Can you post a reply with show run and show flash in an attachment?
files in attachment. i delete identification information from them
I am unable to see ephone configuration in the show run. Has it been removed?
Did you see the phone take the right configuration and firmware by using debug tftp events?
What about the phone locale? Was that downloaded?
Are you at least hearing Russian network locale? i.e. the RU dial-tone, busy tone etc?
When TFTP Event debugging is on i dont have any messages on console.
No. I dont download locale . Where can i download it? I think firmware include locale files .
No i cant hear Russian network locale.
Below 7965g ephone dn configuration for test phone on which i testing language locale
ephone-dn  21  dual-line
 number 9919
 description Test.phone
 name Test.phone
 hold-alert 30 originator
ephone  21
 mac-address  <MAC>
 type 7965
 button  1:21
telephony-service
 sdspfarm units 1
 sdspfarm tag 1 confprof1
 conference hardware
 max-ephones 35
 max-dn 50
 ip source-address  IP port 2000
 system message Trans-IT
 cnf-file location flash:
 cnf-file perphone
 user-locale RU load CME-locale-ru_RU-Russian-10.0.2.7.tar
 network-locale RU
 network-locale 1 RU
 load 7965 SCCP45.9-4-2-1S.loads
 load 6921 SCCP69xx.9-2-1-0
 time-zone 32
 time-format 24
 date-format dd-mm-yy
 max-conferences 4 gain 6
 call-forward pattern .T
 moh "music-on-hold.au"
 web admin system name
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern .T
 create cnf-files version-stamp Jan 01 2002 00:00:00
Anybody know about this problem? How solve it?
i try to download new version of locale files https://software.cisco.com/download/release.html?mdfid=277641082&flowid=45748&softwareid=282786567&release=10.5&relind=AVAILABLE&rellifecycle=&reltype=latest
myabe its helps me
