12-29-2014 01:27 AM - edited 03-17-2019 01:26 AM
Hi all!
I have CME v10 and CP 7965g connected as SCCP phone and want change phone locale to russian .
I upgrade phone firmware, set time zone in telephony-service, recreate cnf files and restart phone. In /its/vrf1/ directory i have xml file SEP<SAME_PHONE_MAC>.cnf.xml with already configured russian locale.
<dateTimeSetting>
<dateTemplate>D/M/Y</dateTemplate>
<timeZone>Russian Standard/Daylight Time</timeZone>
</dateTimeSetting>
<callManagerGroup>
<members>
<member priority="0">
<callManager>
<ports>
<ethernetPhonePort>2000</ethernetPhonePort>
</ports>
<processNodeName> < Gateway IP address > </processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
</devicePool>
<commonProfile>
<callLogBlfEnabled>3</callLogBlfEnabled>
</commonProfile>
<loadInformation>SCCP45.9-4-2-1S</loadInformation>
<userLocale>
<name>Russian_Russia</name>
<langCode>ru_RU</langCode>
<winCharSet>utf-8</winCharSet>
</userLocale><networkLocale>Russian_Federation</networkLocale>
<networkLocaleInfo>
<name>Russian_Federation</name>
</networkLocaleInfo>
But on phone display in locale configuration i have
User Locale : English_United_States
User Locale Char Set : ASCII
How can i change locale on phone?
12-29-2014 02:47 AM
You are seeing En US on the Locale configuration. But what about the softkeys and other menu options? Does that appear in Russian? Or is that also in English?
12-29-2014 03:25 AM
Thanks for your answer
soft keys also in English
12-29-2014 03:31 AM
Can you post a reply with show run and show flash in an attachment?
12-29-2014 06:39 AM
files in attachment. i delete identification information from them
12-29-2014 06:39 AM
I am unable to see ephone configuration in the show run. Has it been removed?
Did you see the phone take the right configuration and firmware by using debug tftp events?
What about the phone locale? Was that downloaded?
Are you at least hearing Russian network locale? i.e. the RU dial-tone, busy tone etc?
12-29-2014 10:49 PM
When TFTP Event debugging is on i dont have any messages on console.
No. I dont download locale . Where can i download it? I think firmware include locale files .
No i cant hear Russian network locale.
Below 7965g ephone dn configuration for test phone on which i testing language locale
ephone-dn 21 dual-line
number 9919
description Test.phone
name Test.phone
hold-alert 30 originator
ephone 21
mac-address <MAC>
type 7965
button 1:21
telephony-service
sdspfarm units 1
sdspfarm tag 1 confprof1
conference hardware
max-ephones 35
max-dn 50
ip source-address IP port 2000
system message Trans-IT
cnf-file location flash:
cnf-file perphone
user-locale RU load CME-locale-ru_RU-Russian-10.0.2.7.tar
network-locale RU
network-locale 1 RU
load 7965 SCCP45.9-4-2-1S.loads
load 6921 SCCP69xx.9-2-1-0
time-zone 32
time-format 24
date-format dd-mm-yy
max-conferences 4 gain 6
call-forward pattern .T
moh "music-on-hold.au"
web admin system name
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp Jan 01 2002 00:00:00
01-11-2015 11:08 PM
Anybody know about this problem? How solve it?
i try to download new version of locale files https://software.cisco.com/download/release.html?mdfid=277641082&flowid=45748&softwareid=282786567&release=10.5&relind=AVAILABLE&rellifecycle=&reltype=latest
myabe its helps me
