05-15-2018 05:24 AM - edited 03-17-2019 12:49 PM
I have Cisco CP-8821 phones and an ISR4331 with CUBE and CUCME functionalities.
According to this document:
"10 Step to configure Cisco Call Manager Express"
https://mrncciew.files.wordpress.com/2013/07/how-to-configure-cme.pdf
- at step 5, I would need a file like "cme-full-4.3.0.0.tar"
- at steps 6 and 7, I would need some ".sbn" and ".loads" files for the phones.
I can't find these files on the ISR4331 that I have.
1. Where should they be located?
2. If they are missing, is there a repository where I can download them?
Please help me.
Best regards.
05-15-2018 05:49 AM
05-15-2018 08:30 AM
Hello.
I've bought my products but received no ID to download any kind of software or files.
Therefore, I have no idea what "CCO" and "software download contract" are.
I am in a great trouble because I can't autonomously download the software and files that I need to configure my products.
05-15-2018 08:34 AM
05-15-2018 08:50 AM
Hello.
Indeed, I am able to download the firmware. That is good.
May I ask you about the other file I mentioned in my initial post:
"10 Steps to configure Cisco Call Manager Express"
Can I get this file or a more recent one too?
05-15-2018 09:07 AM
05-15-2018 09:08 AM
Hello again.
I found this file "CME-COMPLETE-FILESET-12.2.tar" which may be a replacement for "cme-full-4.3.0.0.tar" but I've no idea about that...
I am not allowed to download it as you can see in the image below:
05-15-2018 09:17 AM
05-15-2018 09:34 AM
Hello. Sorry, I didn't see your intermediary answer.
isr4331# show telephony-service CONFIG (Version=10.5) ===================== Version 10.5 Max phoneload sccp version 17 Max dspfarm sccp version 18 Cisco Unified Communications Manager Express For on-line documentation please see: http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html protocol mode default ip source-address UNKNOWN port 2000 ip qos dscp: ef (the MS 6 bits, 46, in ToS, 0xB8) for media cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal af41 (the MS 6 bits, 34, in ToS, 0x88) for video default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup max-ephones 0 max-dn 0 max-conferences 8 gain -6 dspfarm units 0 dspfarm transcode sessions 0 conference software privacy no privacy-on-hold hunt-group report delay 1 hours hunt-group logout DND max-redirect 10 cnf-file location: system: cnf-file option: PER-PHONE-TYPE network-locale[0] US (This is the default network locale for this box) network-locale[1] US network-locale[2] US network-locale[3] US network-locale[4] US user-locale[0] US (This is the default user locale for this box) user-locale[1] US user-locale[2] US user-locale[3] US user-locale[4] US srst mode auto-provision is OFF srst ephone template is 0 srst dn template is 0 srst dn line-mode single time-format 12 date-format mm-dd-yy timezone 0 Greenwich Standard Time no transfer-pattern is configured, transfer is restricted to local SCCP phones only. keepalive 30 auxiliary 30 timeout interdigit 10 timeout busy 10 timeout ringing 180 timeout transfer-recall 0 timeout ringin-callerid 8 timeout night-service-bell 12 caller-id name-only: enable web admin system name Admin web admin customer name Customer edit DN through Web: disabled. edit TIME through web: disabled. background save interval 10 minutes Log (table parameters): max-size: 150 retain-timer: 15 transfer-system full-consult transfer-digit-collect new-call local directory service: enabled. Extension-assigner tag-type ephone-tag.
isr4331#show voice register global CONFIG [Version=10.5] ======================== Version 10.5 Mode is srst Max-pool is 0 Max-dn is 0 Outbound-proxy is enabled and will use global configured value Security Policy: DEVICE-DEFAULT Allow-hash-in-dn is disabled Forced Authorization Code Refer is enabled timeout interdigit 0 network-locale[0] US (This is the default network locale for this box) network-locale[1] US network-locale[2] US network-locale[3] US network-locale[4] US user-locale[0] US (This is the default user locale for this box) user-locale[1] US user-locale[2] US user-locale[3] US user-locale[4] US MWI unsolicited notify is disabled Active registrations : 0 Total SIP phones registered: 0 Total Registration Statistics Registration requests : 0 Registration success : 0 Registration failed : 0 unRegister requests : 0 unRegister success : 0 unRegister failed : 0 Attempts to register after last unregister : 0 Last register request time : Last unregister request time : Register success time : Unregister success time :
Nipun Singh Raghav> Yup, you won't be able to. Talk to your AM regarding and get the contract assigned to your profile if you have already purchased it or you would need to purchase one.
What do you mean by "AM"?
Is this compulsory to get this file to have the system work properly?
In other words, in the document below, can I skip "step 5" without any problem?
05-15-2018 09:41 AM
05-15-2018 09:58 AM
Hello.
I wasn't looking for anything special (for now).
I just want to do the minimum configuration I can with: two wireless phones CP-8821, an ISR4331 with CUBE and CUCME features, a Catalyst Switch (WS-C2960L-24TS-LL) and a Wi-fi WLC/access point (AIR-AP1832I-E-K9).
I need to complete the steps in that document I mentioned earlier ("10 Steps to configure Cisco Call Manager Express") to make my system operational.
Is there a means to know just the contents of this archive ("CME-COMPLETE-FILESET-12.2.tar"): the files list with their names and maybe what they are useful for?
05-16-2018 02:39 AM
The package contains - background images, ringtones, b-acd tcl scripts, moh file, GUI files etc.
There is nothing in the package that is required for phone registration. Its more
from a customization perspective.
05-16-2018 03:01 AM
Hello.
Ok. Thank you very much.
I'll do without it then for now.
