CP 8831-3PCC-K9 conference phone which power cube is compatible?
I have purchased the above conference phone from a big supplier in the US. They claim that the power cube compatible with the phone is  cp-pwr-cube-4 but this cube does not fit. The vendor seem to be unable to give me the correct fitting cube. I have googled cisco product sheet and there is a mention of a Power cube 3? Is this the compatible one for the conference phone 8831? Please advise!
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Power requirements
The Cisco Unified IP Conference Phone 8831 is an interoperable IEEE 802.3af PoE (Class 3 device); 48 VDC is required; it can be supplied locally at the desktop using an optional AC-to-DC power supply (CP-PWR-CUBE-3=). Use of the power supply also requires the use of one of the corresponding AC country cords listed in Table 7 later in this document.
Use of a power supply (CP-PWR-CUBE-3=) is required when using the Cisco Unified IP Conference Phone 8831 in a daisy-chain configuration.
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/data_sheet_c78-726887.html
java
if this helps, please rate
Thanks a lot for this reply!
Med vänliga hälsningar, Best regards, Met vriendelijke groet,
___________________________________
Helena Gustafsson
Administrator
Trinseo Sverige AB
T: +4611245220
www.trinseo.com<>
Styron is now Trinseo
Connect with Us
[http://www.styron.com/image/signature/styron-icon3.png]<> [http://www.styron.com/image/signature/twitter-icon3.png] <> [http://www.styron.com/image/signature/facebook-icon3.png] <> [http://www.styron.com/image/signature/linkedin-icon3.png] <> [http://www.styron.com/image/signature/youtube-icon3.png] <>
Recognize Your Peers
