CP-8831 built-in mic
Chi Fai Leung
I bought the CP-8831 Conference Phone to replace the CP-7937, that use the built-in mic only (No the wireless / wired mic)
I'm using on the small conference room. As the CP-7937, the calling out sound is very clear and the receiver caller hear is good. But it is bad on the CP-8831. Why? The same small conf. rm.
Must I purchase the external mic for CP-8831?
I just searched some doc said the 8831 build in mic provide the 360 degree audio coverage via four built-in mic. Should I disable two built-in mic?
Ahmad Kefaya
Hello
