CP-8831 IP Conference Phone
peternnaji
Beginner
Beginner
Can anyone help about the CP-8831 IP Conference Phone?
I want to know whether the Wired and wireless Microphone can be used simultaneously on the Base conference phone.
Also, can there be more that two wireless microphones when it is configured for daisy chain?
Peter,.
Anas Abueideh
Engager
Engager
it can support only 2 wired min and 2 wireless mic. kindly find the below link
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps12965/data_sheet_c78-726887.pdf
Anas
please don't forget to rate the helpful posts
Anas Abueideh
Engager
Engager
Anas
gabaeza
Beginner
Beginner
Actually it can only support one of both; it is either/or. If you connect both wired and wireless, then the system will prioritize wireless MICs and disable the wired MICs.
Recognize Your Peers
