CP-8841 Distance limitations from data switch port.
daleshew517
Good Afternoon,
One of the departments in our hospital is wanting a Cisco CP-8841 telephone on the second floor of their building.  The network switches on that floor are not ready to support VOIP yet but the ones on the 14th floor are.  Does anyone know the maximum data cable distance from a switch port that a CP-8841 phone with no computer can tolerate?  If necessary, we can use a power cube instead of POE.
Dale Shew
Prassha
Hello daleshew517
You probably need to use power adapter but to answer you primary question distance requirement by the Ethernet Specification, the maximum cable length between IP Phone and the switch should not be more than 100 meter. I hope this answer your query.
Prassha3
Rate if you find this helpful
Rate if you find this helpful or Mark Solutions as Accepted
Prassha
Hello daleshew517
Prassha3
Thanks Prassha.  That definitely answers my question.
Leo Laohoo
Distance is not the only "limitation" of the cable run.
100 metres is the effective distance of 100BaseTx and PoE.
The number of cable pairs terminated also dictates whether or not each port can run 1 Gbps or PoE.
