04-15-2021 05:33 PM
I'm trying to upgrade the firmware but I keep getting file not found. Using http://url/firmware.loads in the Upgrade Rule. The error I get is "File Not Found".
If I cut and past the Upgrade Rule URL in a browser, it immediately goes to download the file -- no typos.
I tried an https site as well and the same thing happened.
Looking for an http solution to upgrade the firmware?
Note: Not interested local TFTP solution. Every other vendor has a cloud provisioning server for free that makes stuff like this easy. This should be easy.
Any help appreciated.
04-16-2021 01:58 AM
What the is current firmware on the phone?
Also, can you please list your upgrade files? Just want to be sure you have all the correct files for the upgrade.
04-16-2021 09:04 AM
