That's impossible, there is no path from enterprise to 3PCC, or the other way for that matter.
If you wanted to use the devices with a 3rd party PBX, you had to buy the 3PCC models.
If you're running enterprise FW, you can only use the .xml files to manually tweak the configuration for 3rd party PBX registration.
java
if this helps, please rate
