06-26-2012 12:55 PM - edited 03-16-2019 11:51 AM
Does anyone know the file name that is populated in the "Load Information" field on the Device Defaults page of CUCM 7.1.5 for an 8945 SCCP phone for firmeware cmterm-8941_8945-sccp.9-3-1-19.cop.sgn?
joe.
06-27-2012 12:28 AM
I don't have that exact firmware on my system, but based on other versions I've got, I'd assume a loadname of
SCCP894x.9-3-1-19
The way to find for sure, is go to https://x.x.x.x/cmplatform on your TFTP server, Software Upgrades -> TFTP File Management. Search for files with 894x in the name. Look for the file that ends with ".loads" and use it's name (excluding the .loads suffix)
GTG
06-27-2012 04:49 AM
be carefull with this version its buggy, the directory button does not work also if your using IPCC the phone no longer shows the login screen
colin
