cptone RU parameters???
e_kniazev1974
Hi ALL!
Where I can find parameters which Cisco using in standard cptone RU?
These is the following:
dualtone busy - what frequency and cadence?
dualtone ringback- what frequency and cadence?
dualtone disconnect- what frequency and cadence?
I can't find it on cisco.com :(
Thank a lot.
Thanks.
I found this link early
but unfortunately I can't in this document
what parameters of freq/ and cadence Cisco mean when configure voice port
by command
cptone RU
I think this is what you're looking for:
test voice tone RU show
Here's output:
nicmatth-sip#test voice tone RU show
Code: RU Country: Russian Federation
DTMF freq.(Hz) Row / col: 697, 770, 852, 941 / 1209, 1336, 1477, 1633
Pulse dial: normal, Percent make: 35%, DTMF low Amp. = 65446, high Amp. = 65446, Pcm: a-Law
Tone NF FOF FOS AOF_FXS AOF_FXO AOF_EM AOS_FXS AOS_FXO AOS_EM ONTF OFTF ONTS OFTS ONTT OFTT ONT4 OFT4
BUSY 1 425 0 -200 -200 -200 0 0 0 500 500 0 0 0 0 0 0
RING_BACK 1 425 0 -100 -100 -100 0 0 0 800 3200 0 0 0 0 0 0
CONGESTION 1 425 0 -200 -200 -200 0 0 0 250 250 0 0 0 0 0 0
NUM_UNOBTAINAB 1 425 0 -200 -200 -200 0 0 0 250 250 0 0 0 0 0 0
DIALTONE 1 425 0 -150 -150 -150 0 0 0 65535 0 0 0 0 0 0 0
DIAL_TONE2 1 425 0 -150 -150 -150 0 0 0 65535 0 0 0 0 0 0 0
OUT_OF_SERVICE 1 950 0 -150 -150 -150 0 0 0 330 330 0 0 0 0 0 0
ADDR_ACK 1 600 0 -240 -240 -240 0 0 0 125 125 125 65535 0 0 0 0
DISCONNECT 1 600 0 -150 -150 -150 0 0 0 330 330 330 65535 0 0 0 0
OFFHOOK_NOTICE 1 425 0 -200 -200 -200 0 0 0 500 500 0 0 0 0 0 0
OFFHOOK_ALERT 1 425 0 -200 -200 -200 0 0 0 500 500 0 0 0 0 0 0
-nick
