Crash Phone
Anyone have idea on crash phone solution in Cisco which when the call coming from outside it should ring on three extensions or more; all extensions have to keep ringing although one of them take the line in addition to in case two of them take the line at the same time or after each other, it will be call conference automatically between the caller and whoever take the line internally.
Jaime Valencia
You need to mention what products you're using, or have available (and versions), and not just what you want.
java
if this helps, please rate
Hi Jaime,
I am using CUCM version 10.5 with Cisco SIP and SCCP phones.
There is no native feature that would do this in CUCM.
java
Thanks for the info.
