create a new BAT for CUCM and CUPS
ivan aguilar
Level 6
Level 6
Hi!
I need to now what are the steps to get the BAT file in CUCM and CUPS. I have found how to import that file created, but i dont see how to get it, please anybody could help me??
Regards!
slashdots
Level 5
Level 5
I'm not sure what you mean.
If your not sure how to create the bat file:
Just go to "Bulk Administration"-> CUPS -> "view sample file"
Create a txt file which looks like the one you just viewed.
The sample file will probaly look like:
User ID,Enable CUP,Enable CUPC
xmzhou,t,t
ddaiker,t,f
After creating the file upload the file under:
"Bulk Administration" -> "Upload/Download Files"
-Click on Add new
- Add your custom file
- Select CUP-User as Target
- Select CUP-User Update as transaction type
After adding the File to Bulk Administration you should be able to select it under "Bulk Administration" -> CUPS -> "Update CUPS/CUPC Users"
Ok!
Thanks, i need to create a new BAT, as a backup of all users and phone, because after it i need to upload that information.
So create a new BAT is like a make a backup?
Regards.
No,  it's not a Backup.
My description is leading to a new configuration.
If you want to export the Information as a Backup:
- go to "CUPS -> "Export CUPS/CUPC Users"
- filter the users you want to export
- enter a Filename and start the job
This will not backup the users or phones itself.
You also can export a list of phones and users under the Bulk Administration.
If you wan't to have a proper system backup, I recommend you configuring a propper backup under "Desaster Recovery System"
