01-09-2018 12:26 AM - edited 03-17-2019 11:54 AM
dear
im trying to create dial-peer voice pots but its shown an error: could not add peer as per attached pic
The "ERROR: could not add peer" error message is displayed on the IOS voice gateway when an attempt is made to add a dial peer to an existing dial-peer configuration
how can i deal with memory is there is any way to fix for adding new dial peer?
Solved! Go to Solution.
01-15-2018 01:44 AM
That would depend on your environment and how "busy" your router is. Also, high RAM utilization is usually seen in boxes with large routing (eg BGP) tables and if they run multiple functionalities (extra zone-based firewalls etc).
Of-course, since the 2911 has only one DRAM slot, if you can take over the extra cost of the 2GB DIMM it would be good to purchase it, since you never know how you will be using the router in the future. But, to serve as a voice gateway in a normal enterprise, the 1GB DIMM should be enough.
01-09-2018 12:47 AM
Router(config)#do show mem
Router(config)#do show memory
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 3D532A60 279012668 270675704 8336964 6154952 5940408
I/O D800000 41943040 18533860 23409180 23225424 18813388
Reserve 3E7AA2A8 262144 52 262092 262092 262092
01-09-2018 12:53 AM
Can you attach the output of "show version" and "show memory summary"? If nothing weird is happening on your router the only way to free some memory up is:
- Use an IOS that requires less RAM (you will probably have to downgrade here)
- Disable unused services on the router (http/dhcp server)
- Remove unused dial-peers
01-09-2018 01:05 AM
please find o/p:
Router#show memory summary
Processor 3D532A60 279012668 270621796 8390872 6154952 5940408
Router#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sat 25-Oct-14 03:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 8 weeks, 2 days, 42 minutes
System returned to ROM by reload at 08:09:01 UTC Sun Nov 12 2017
System image file is "flash0:c2900-universalk9-mz.SPA.154-3.M1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ190360AM
3 Gigabit Ethernet interfaces
1 terminal line
8 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2911/K9 FCZ190360AM
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
NtwkEss None None None
CollabPro None None None
01-09-2018 01:09 AM
note: i have only 15 ip cisco phone connected
Router#show run
Building configuration...
Current configuration : 13047 bytes
! Last configuration change at 08:47:37 UTC Tue Jan 9 2018 by amr
version 15.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$l9ha$dHLj/scp8Qm8C77UcUa/K0
enable password .......
no aaa new-model
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.2.207
ip dhcp pool voice
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.207
option 150 ip 192.168.2.207
dns-server 8.8.8.8 8.8.4.4
ip dhcp global-options
dns-server 163.121.128.134 163.121.128.135
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
trunk group Mobile
trunk group pstn
cts logging verbose
crypto pki trustpoint TP-self-signed-2728187941
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2728187941
revocation-check none
rsakeypair TP-self-signed-2728187941
crypto pki certificate chain TP-self-signed-2728187941
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373238 31383739 3431301E 170D3135 30333231 31333235
31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37323831
38373934 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C184 ACFFFB46 C4C5B385 CBE1A6C9 0CD5DA07 385B1D99 C8AD86D5 9CFAA109
CACAA786 2AE1D32F CC3AC285 BBA7B419 04B2482A 0B7DD955 99130F92 48B2A075
E8B170CA 230036B1 73D4F8FF 26E2B556 6FD337BE 3A8B341B 0A80C612 6737B714
96CFA520 995A0E45 993F558D 1DFC222A 3F587ABE E3E1F038 3CA3152F F0222271
00330203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14AEA7B2 0A72790D BDCE8BF7 9C2D6CF2 C1C8A393 5B301D06
03551D0E 04160414 AEA7B20A 72790DBD CE8BF79C 2D6CF2C1 C8A3935B 300D0609
2A864886 F70D0101 05050003 81810072 94945FF4 84A78DF0 CF361867 79566C0F
D6FB48FD 3ACB218F 800D5CA1 54F4F4E2 5ED04E26 4A5DC612 097EE5D0 5A26618A
80DB770F 30768D27 C5F7679A D5E81483 C3993CC4 15CFF495 39F11F9D 7EE9054D
DC5CDEEE B3E35F53 09DB553A EACEE590 D128A220 52EE5C32 FCA5A626 BDAD34D5
6DABFE4F F30D63A5 5C92E27A 7E3EE0
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711ulaw
h323
sip
registrar server
voice register global
mode cme
source-address 192.168.2.207 port 5060
max-dn 64
max-pool 58
load 7821 sip78xx.10-1-1-9.loads
timezone 25
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0000212587445944
network-locale GB
voice register dn 1
voice register dn 5
number 100
name Inas AlMahalawi
label Inas AlMahalawi
mwi
voice register dn 6
number 101
name Meeting Room A
label Meeting Room A
mwi
voice register dn 7
number 102
call-forward b2bua noan 5 timeout 20
name Walid Hifny
auto-answer
label Walid Hifny
mwi
mobility
voice register dn 8
translation-profile incoming amr
translation-profile outgoing alrazzaz
number 103
call-forward b2bua noan 113 timeout 20
allow watch
pickup-call any-group
name Amr AL-Razzaz
shared-line
auto-answer
label Amr AL-Razzaz
mwi
mobility
voice register dn 9
number 104
name Khaled Elgarhy
label Khaled Elgarhy
mwi
voice register dn 10
number 105
name Sales 2
label Sales 2
mwi
voice register dn 11
number 107
name Amr Ismail
label Amr Ismail
mwi
voice register dn 12
number 108
name Mohammed Abdella
label Mohammed Abdella
mwi
voice register dn 13
number 109
name Sales 1
label Sales 1
mwi
voice register dn 14
number 110
name Karim Habib
label Karim Habib
mwi
voice register dn 15
number 114
name Tamer Mazen
label Tamer Mazen
mwi
voice register dn 16
number 115
name Meeting Room B
label Meeting Room B
mwi
voice register dn 17
number 106
name Conference Room
label Conference Room
mwi
voice register dn 18
number 112
name Omar Mohamed
label Omar Mohamed
mwi
voice register dn 19
number 113
name Marketing
label Marketing
mwi
voice register pool 5
busy-trigger-per-button 1
id mac 5067.AE21.4E6E
type 7821
number 1 dn 5
cor incoming mobile-long default
presence call-list
dtmf-relay rtp-nte
username ....... password
codec g711ulaw
voice register pool 6
pin 4100
id mac 5067.AE21.4EA5
type 7821
number 1 dn 6
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 7
id mac 5067.AE21.9A74
type 7821
number 1 dn 7
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 8
id mac 5067.AE21.9A5A
type 7821
number 1 dn 8
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 9
id mac 5067.AE21.99AC
type 7821
number 1 dn 9
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 10
id mac 5067.AE21.9A52
type 7821
number 1 dn 10
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 11
id mac 5067.AE21.9A1D
type 7821
number 1 dn 11
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 12
id mac 5067.AE21.4F10
type 7821
number 1 dn 12
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 13
id mac 5067.AE21.4E15
type 7821
number 1 dn 13
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 14
id mac 5067.AE21.4DF7
type 7821
number 1 dn 14
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 15
id mac 5067.AE21.4EAD
type 7821
number 1 dn 15
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 16
id mac 5067.AE21.4E9D
type 7821
number 1 dn 16
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 17
id mac 5067.AE21.4DD6
type 7821
number 1 dn 17
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 18
id mac 5067.AE21.4F96
type 7821
number 1 dn 18
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 19
id mac 5067.AE21.4F9C
type 7821
number 1 dn 19
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
license udi pid CISCO2911/K9 sn FCZ190360AM
license accept end user agreement
hw-module pvdm 0/0
username cisco password 0 cish:
username .......... secret 5 $1$5Klr$GneBF.AwmAgvMY4lW/Ylk1
username aa
username Acc
username ......... privilege 15 secret 9 $9$eSfWH2ACcyEpgU$kBe69JmDRjwR01pDNDUjBF17G2JI8hOCafvoaptS8f6
redundancy
process-max-time 50
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.2.207 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 192.168.1.207 255.255.255.0
ip nat outside
ip rip advertise 100
ip rip receive version 2
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
router rip
network 192.168.1.0
network 192.168.2.0
ip default-gateway 192.168.2.207
ip forward-protocol nd
ip http server
ip http secure-server
ip http path flash:
ip flow-export version 9
ip flow-export destination 192.168.2.195 9996
ip flow-top-talkers
top 50
sort-by packets
ip dns view default
dns forwarder 8.8.8.8
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source list 150 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
snmp-server community public RO
tftp-server flash:kern78xx.10-1-1-9.sbn
tftp-server flash:rootfs78xx.10-1-1-9.sbn
tftp-server flash:sboot78xx.10-1-1-9.sbn
tftp-server flash:sip78xx.10-1-1-9.loads
tftp-server flash:rootf2
access-list 1 permit 192.168.2.0
access-list 150 permit ip any any
control-plane
voice-port 0/0/0
trunk-group Mobile
connection plar opx 100
description Configured by 2911 4 FXO-0/0/0-Custom
caller-id enable
voice-port 0/0/1
trunk-group Mobile
description Configured by 2911 4 FXO-0/0/1-Custom
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
mgcp profile -long
dial-peer cor custom
name internal
name pstn
name long
name mobile
name international
dial-peer cor list internal
member internal
dial-peer cor list mobile-long
member internal
member pstn
member long
member mobile
dial-peer cor list manager
member internal
member pstn
member long
member mobile
member international
dial-peer voice 8 pots
trunkgroup long
trunkgroup Mobile
corlist outgoing mobile-long
destination-pattern 904......T
prefix 04
dial-peer voice 9 pots
trunkgroup long
trunkgroup Mobile
destination-pattern 905......T
prefix 05
dial-peer voice 22 pots
service stcapp
port 0/0/2
dial-peer voice 10 pots
trunkgroup long
trunkgroup Mobile
trunkgroup Inter
trunkgroup international
corlist outgoing manager
description **Cairo**
destination-pattern 900T
prefix 00
dial-peer voice 2 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **shortcut No**
destination-pattern 91[16789]...
forward-digits 5
dial-peer voice 3 pots
trunkgroup long
trunkgroup PSTN
description ** Services **
destination-pattern 91[1245].
forward-digits 3
prefix 013
dial-peer voice 7 pots
trunkgroup long
trunkgroup Mobile
description **Alex**
destination-pattern 903......T
prefix 03
dial-peer voice 15 pots
dial-peer voice 2000 voip
description ** Sedestination-pattern 9013.T
destination-pattern 402
b2bua
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1 pots
trunkgroup pstn
trunkgroup Mobile
description ** Inside Cairo **
paramspace callsetup after-hours-exempt FALSE
destination-pattern 902.......T
fax rate disable
no digit-strip
forward-digits 8
prefix 02
no register e164
preemption level flash-override
dial-peer voice 4 pots
trunkgroup Mobile
description ** Mobile **
destination-pattern 901[012]........
forward-digits 11
dial-peer voice 6 pots
trunkgroup long
trunkgroup Mobile
description **sharm alsheikh**
destination-pattern 9069......T
prefix 069
dial-peer voice 11 pots
trunkgroup long
trunkgroup Mobile
prefix 00
dial-peer voice 12 pots
prefix 00
dial-peer voice 21 pots
service stcapp
port 0/0/1
dial-peer voice 13 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **Vodafone**
destination-pattern 92[47].
forward-digits 3
gatekeeper
shutdown
telephony-service
max-ephones 58
max-dn 64
ip source-address 192.168.2.207 port 2000
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
max-conferences 8 gain -6
web admin system name romani password cisco
web admin customer name romani1 password cisco
dn-webedit
time-webedit
transfer-system full-consult dss
ephone-dn 1 dual-line
number 111 no-reg primary
label 111
description Mr. Jeries Alghwaly
name Mr. Jeries Alghwaly
ephone 1
video
mac-address 1CE8.5DC8.D374
username "aa"
paging-dn 1
type 7945
button 1:1
pin 4100
ephone 2
ephone 5
line con 0
password cisco
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
01-09-2018 04:15 AM
Indeed you have very little free processor memory. You platform and configuration does not justify the huge memory usage.
Can you share the output of show processes memory sorted (just the first few lines). I would also suggest reboot your router and take the output of the show commands again.
Also, remove these lines from your config, it is not safe having them:
username aa
username Acc
01-09-2018 05:29 AM
dear thanks for ur great supprot
here u r the o/p
Router#show processes memory sorted
Processor Pool Total: 279012668 Used: 271080624 Free: 7932044
I/O Pool Total: 41943040 Used: 18560144 Free: 23382896
Reserve Pool Total: 262144 Used: 48 Free: 262096
PID TTY Allocated Freed Holding Getbufs Retbufs Process
174 0 155826908 6040812 149796616 0 0 IP ARP Adjacency
0 0 231473908 147692040 75427700 0 0 *Init*
246 0 98026556 81866688 15159768 94640 780 ADJ resolve proc
429 0 18530916 12005160 6531892 0 0 STILE PERIODIC T
01-09-2018 05:34 AM
The ARP/ADJ holdings are pretty high. Can you also include the first lines of show processes cpu sorted and look if there is anything weird in show arp.
01-10-2018 11:48 PM
Router#show processes cpu sorted
CPU utilization for five seconds: 2%/1%; one minute: 2%; five minutes: 2%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
212 29472 83224 354 0.39% 0.41% 0.39% 0 ADJ background
198 124 10563641 0 0.15% 0.20% 0.21% 0 Ethernet Msec Ti
3 1936 286196 6 0.15% 0.16% 0.15% 0 Skinny Msg Serve
88 124 83411 1 0.07% 0.04% 0.03% 0 Per-Second Jobs
132 80 1302043 0 0.07% 0.04% 0.05% 0 VRRS Main thread
122 188 166770 1 0.07% 0.02% 0.02% 0 BPSM stat Proces
176 21148 162453 130 0.07% 0.06% 0.07% 0 IP Input
286 88 1302043 0 0.07% 0.03% 0.02% 0 MMA DB TIMER
116 236 63 3746 0.07% 0.27% 0.07% 388 Virtual Exec
172 72 2599646 0 0.07% 0.04% 0.05% 0 IPAM Manager
10 0 274 0 0.00% 0.00% 0.00% 0 WATCH_AFS
11 0 1 0 0.00% 0.00% 0.00% 0 License Client N
9 0 2 0 0.00% 0.00% 0.00% 0 Timers
also arp
Router#show arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 1.38.7.33 162 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.16.146.79 163 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.18.124.164 179 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.18.168.252 17 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.18.171.114 113 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.18.171.170 250 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.18.172.96 38 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.18.175.102 86 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.18.175.142 93 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.19.16.75 98 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.19.18.82 132 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.19.18.222 150 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.19.27.190 77 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.19.30.235 66 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.19.189.74 50 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.20.27.78 139 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.20.194.90 79 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.20.196.12 100 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.20.200.150 140 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.20.202.119 207 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 2.22.119.33 0 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.9.158.254 77 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.11.87.86 89 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.11.87.124 61 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.11.87.184 36 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.57.16.96 119 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.57.16.99 240 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.57.16.100 22 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.57.16.220 98 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.57.17.72 25 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.57.17.96 97 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.57.17.99 114 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.57.17.100 113 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.57.17.220 99 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.79.46.84 88 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 5.153.15.173 96 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 8.5.1.18 77 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 8.8.4.4 128 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 8.8.8.8 140 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 8.18.25.6 240 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 8.36.113.139 56 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 8.41.222.241 53 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.26.188.155 16 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.38.0.161 60 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.38.0.223 64 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.38.1.175 45 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.100.44.23 59 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.100.44.31 60 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.100.44.34 47 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.100.44.95 71 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.100.44.96 27 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.100.44.142 44 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.100.44.143 46 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.209.168.96 178 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.215.12.20 38 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.215.12.21 86 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.215.12.22 75 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 10.215.12.23 25 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.57.147.3 179 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.57.156.82 65 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.57.158.110 89 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.69.159.30 103 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.74.34.99 112 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.74.179.117 49 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.77.92.139 127 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.78.180.50 10 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.79.239.69 87 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.80.122.206 142 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.81.65.66 125 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.82.54.245 50 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.90.95.57 67 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.95.234.10 84 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.95.235.62 121 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.95.236.192 90 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.100.0.231 73 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.107.3.128 130 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.107.4.50 86 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.107.4.52 134 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.107.5.80 74 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.107.5.88 124 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.107.6.151 144 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.107.6.156 82 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.107.18.11 240 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.107.19.11 52 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.107.21.200 85 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.107.42.11 126 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.114.89.54 183 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.115.22.130 139 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.229.69.139 28 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.229.115.42 5 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 13.250.84.232 248 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 14.215.165.8 46 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 14.215.165.10 135 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 14.215.165.17 52 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 14.215.165.19 134 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 14.215.165.20 75 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 15.49.72.109 41 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 15.51.72.99 61 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 15.72.238.30 36 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 15.73.96.91 31 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 17.36.205.4 146 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 17.42.252.6 72 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 17.42.252.8 110 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 17.42.252.9 96 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 17.42.252.10 191 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 17.42.252.11 138 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 17.42.252.14 124 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 17.42.252.17 113 54a2.746a.1b21 ARPA GigabitEthernet0/1
Internet 17.42.252.18 42 54a2.746a.1b21 ARPA GigabitEthernet0/1
01-11-2018 12:02 AM
What does your "show memory summary" say now? Also, please note the comment of @Balram Vishwakarma and adapt accordingly.
For now, I propose reload the router and attach the output of the commands again.
01-11-2018 12:11 AM
i already reloaded it yesterday and here u are the o/p memory right now
Processor 3D52A4E0 279046844 104074136 174972708 44837008 146845864
I/O D800000 41943040 18559812 23383228 23300332 23104380
Processor memory
Alloc PC Size Blocks Bytes What
0x30009F34 0000000024 0000000025 0000000600 TW Wheels
0x30009F34 0000000032 0000000004 0000000128 TW Wheels
0x30009F34 0000000048 0000000001 0000000048 TW Wheels
0x30009F34 0000000052 0000000003 0000000156 TW Wheels
0x30009F34 0000000060 0000000001 0000000060 TW Wheels
0x30009F34 0000000072 0000000001 0000000072 TW Wheels
0x30009F7C 0000000512 0000000035 0000017920 TW Buckets
0x30009F7C 0000000560 0000000001 0000000560 TW Buckets
0x30009F7C 0000001024 0000000005 0000005120 TW Buckets
0x30009F7C 0000002048 0000000006 0000012288 TW Buckets
0x30009F7C 0000004096 0000000012 0000049152 TW Buckets
0x30009F7C 0000008192 0000000020 0000163840 TW Buckets
0x30009F7C 0000016384 0000000051 0000835584 TW Buckets
0x3000A76C 0000000032 0000000001 0000000032 TW timer Table
0x3000A76C 0000000056 0000000001 0000000056 TW timer Table
0x3000A76C 0000000080 0000000001 0000000080 TW timer Table
0x3000A76C 0000000088 0000000001 0000000088 TW timer Table
0x3000A76C 0000000512 0000000001 0000000512 TW timer Table
0x3000BD58 0000000116 0000000001 0000000116 Managed Chunk Queue Elements
0x3000D658 0000000104 0000000001 0000000104 SSM SH inQ interrupt chunk msgs
0x3000D658 0000000136 0000000001 0000000136 SSM CM inQ msgs
0x3000D658 0000000168 0000000002 0000000336 DSensor Malloc
0x3000DE80 0000000172 0000000001 0000000172 MallocLite
0x3000DE80 0000000188 0000000005 0000000940 MallocLite
0x3001C4E4 0000000960 0000000001 0000000960 Check heaps
0x3001C518 0000001728 0000000001 0000001728 Check heaps
0x3001F4C8 0000000400 0000000001 0000000400 *Init*
0x300221AC 0000000024 0000000006 0000000144 (fragment) (Free Blocks)
0x300221AC 0000000044 0000000001 0000000044 (fragment) (Free Blocks)
0x300221AC 0000000056 0000000001 0000000056 (fragment) (Free Blocks)
0x300222A4 0000000024 0000000003 0000000072 (fragment) (Free Blocks)
0x300222A4 0000000028 0000000004 0000000112 (fragment) (Free Blocks)
0x300222A4 0000000032 0000000001 0000000032 (fragment) (Free Blocks)
0x300222A4 0000000040 0000000001 0000000040 (fragment) (Free Blocks)
0x300222A4 0000000060 0000000001 0000000060 (fragment) (Free Blocks)
0x300222A4 0000000068 0000000001 0000000068 (fragment) (Free Blocks)
0x300222A4 0000000076 0000000001 0000000076 (fragment) (Free Blocks)
0x30026E40 0000016540 0000000008 0000132320 pak subblock chunk
0x30026E40 0000020000 0000000001 0000020000 pak subblock chunk
0x30026E40 0000032768 0000000004 0000131072 pak subblock chunk
0x30026E40 0000065536 0000000012 0000786432 pak subblock chunk
0x30026F38 0000002180 0000000001 0000002180 pak subblock chunk
0x30026F38 0000002336 0000000001 0000002336 pak subblock chunk
0x30026F38 0000003092 0000000001 0000003092 pak subblock chunk
0x30026F38 0000016540 0000000001 0000016540 pak subblock chunk
0x30026F38 0000020000 0000000001 0000020000 pak subblock chunk
0x30026F38 0000032768 0000000001 0000032768 pak subblock chunk
0x3002F85C 0000000116 0000000006 0000000696 Normal
0x3002F85C 0000000628 0000000002 0000001256 IDS SM
0x3002F85C 0000004212 0000000008 0000033696 GigabitEthernet0/0
0x3002F85C 0000008192 0000000001 0000008192 IDS SM
0x3002F85C 0000065536 0000000004 0000262144 Backplane-GigabitEthernet0/3
0x3002F910 0000000408 0000000028 0000011424 HQF Particle
0x3002F910 0000000428 0000000060 0000025680 Normal
0x3002F910 0000004676 0000000028 0000130928 HQF Particle
0x3002F910 0000005000 0000000060 0000300000 Normal
0x3002F924 0000000260 0000000129 0000033540 Normal
0x3002F924 0000000876 0000000011 0000009636 HQF Particle
0x3002FC84 0000065536 0000000001 0000065536 Clones
0x300384EC 0000010852 0000000001 0000010852 Alignment Data
0x30043870 0000000352 0000000028 0000009856 Pool Info
0x30044050 0000000512 0000000001 0000000512 Pool Cache
0x30044050 0000001200 0000000001 0000001200 Pool Cache
0x30044050 0000002048 0000000002 0000004096 Pool Cache
0x30044050 0000004096 0000000004 0000016384 Pool Cache
0x3004B46C 0000004676 0000000002 0000009352 Memory RO RU In
0x3004B46C 0000005000 0000000001 0000005000 Memory RO RU In
0x3004B4D8 0000065536 0000000002 0000131072 Memory RO User
0x3004D2A8 0000000116 0000000001 0000000116 Memory RO RU Index Chunks
0x3004D304 0000000116 0000000001 0000000116 Memory RO User Info Chunks
0x3004D36C 0000000116 0000000001 0000000116 Memory RO Notification chunk
0x3004DA9C 0000000040 0000000001 0000000040 *Init*
0x3004FA14 0000000120 0000000001 0000000120 Init
0x3004FA44 0000000120 0000000001 0000000120 Init
0x3004FB00 0000000168 0000000001 0000000168 Init
0x3004FB9C 0000000116 0000000001 0000000116 Memory GTE chunk
0x300536B0 0000010000 0000000001 0000010000 List Elements
0x30053B38 0000010000 0000000001 0000010000 List Elements
0x30053D8C 0000010000 0000000011 0000110000 List Elements
0x300545F0 0000010000 0000000001 0000010000 List Elements
--More--
01-10-2018 04:25 AM
01-11-2018 12:09 AM
thanks alot Balram Vishwakarma for helping i already restart the router and problem solved
so if i wanna change the ram so is it easy like desktop pc just remove the old and install the new one ?
if i upgrade the memory the configurations will be deleted or effected?
also after i reboot the router the problem fixed .. but how to avoid from happening again or when it will happen again ?
01-11-2018 12:27 AM
01-11-2018 12:44 AM
what size of ram should u recommend to me and how many slots inside device ?
i can get new memory 1 gb for example and add it on the old one 512mb to be 1.5 gb ?
