Create RTMT Alert for MGCP T1 Port unregistering
calicolin1
Is it possible to create an RTMT alert if an MGCP T1 Port unregisters? I encountered a situation where the D Channel of a PRI stayed up, and for all intents an purposes, it seemed to the telco that the circuit was operational so they kept sending us calls. However in CUCM when you find the gateway, the MGCP T1 port was showing unregistered. To resolve the issue I had to go into the gateway itself and shut / no shut Controller T1 0/0/0. Then in CUCM the T1 port showed registered again and all was normal. I would like an alert generated if this occurs again.
Nadeem Ahmed
Yes it can be through RTMT tool. please refer this how to configure the same
http://www.netcraftsmen.com/creating-custom-alerts-in-rtmt/
Br,
Nadeem Ahmed
PS: Please rate all usefull post.
Br, Nadeem Please rate all useful post.
I did in fact use that same article to look for a way to alert on an un-registered MGCP T1 Port. I am only able to find custom alerts for Channel Status, DatalinkInService, and RegisteredMGCPGateway. I believe all of those would have shown normal during the event I had this morning. Even though the T1 Port was showing unregistered in CUCM, Channel23 looked fine in the gateway.
