5751
Highlighted
Contributor
Critical Error : CUCM 9.1.2 Installation failed with return-code 256
Hi all,
The installation aborted with the following error message, any ideas on why this could happen? How can I access the mentioned path? How can I get the dump logs?
14 REPLIES 14
Highlighted
Hall of Fame Cisco Employee
What HW are you using?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Highlighted
Hi Jaime,
I'm using Vmware v8, but didn't deploy with .ova from cisco.
Fikri
Highlighted
Then, you should be using the OVA from Cisco, and that's not HW what you just replied.
I'll take it you're running ESXi 5 from the V8, but again, that does not answer the question, that's not HW.
java
java
Highlighted
Hi Jaime,
Sorry for my answer, I find it hard to focus at these hours sometimes :(. I believe what you are asking is the general specs of the VM :
Highlighted
what server are you using? Is it ucs c220 or some third party server?
Highlighted
Hi I have also same issue.
i am runing ucs c200 M2 server .
Esxi 5.0
After taking a  two-three hours not able to install getting same issue.
d
