critical error on CME
akram.root
Level 4
Level 4
Hello all,
i have a problem with of registration ip phone SIP (7841-8851) on ISR 4351/K9.the problem is when i power off the gateway.
the ip phone Keeps the same interface without rebooting.when i power  on the gateway , I have every time to reset the ip phones so that they
function.
can you help me please the resolve this issue .
It encloses the configuration file and the version of the gateway ISR.
help me please it's very urgent.
Best regards
Akram
11 Replies 11
mudasserilyas
Hi Akram,
I have faced many abnormal issues with the SIP phones registering to the Cisco CME. But most of my issues got solved using this method.
Check your CME version by #show telephony-service. Then downgrade or upgrade the Cisco IP Phone firmware as compatible with the same version. I am giving you the example of my scenario which I did back then. I was using the same ISR4300 Router with CME 10.5. I downgraded my IP phone firmware to match this guide...
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme105spc.html
As I see your Phone firmware, they are among the latest like mine. But after downgrading the firmware as in the sheet, my issues were resolved Alhamdulillah.
Let me know if this resolves your issue.
thank you for your reply,
Here it is attached ' show telephony service'
and i have firmware 10.3.1
what i can do to resolve this issue
thank you
Can you share me the #show telephony-service output?
There is no 10.3.1 in the compatibility matrix page for the CME. Maybe you can check with the 10.0 version. Or you can double check your CME version and then choose from the following link.
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-express/products-device-support-tables-list.html
I hope this will resolve your issue. Please let us know the status.
i would like to install ios 10:0 of CME in my gateway
could you give me the method ?
Best regards
Akram
Sorry for late reply. I have been busy.
Ramadan Kareem, May God bless you in this blessed month. ameeen
The different iOS versions for ISR 4351 can be found here. I will sugggest to download the latest suggested by the Cisco because many bugs are fixed and it has latest features.
The upgrade of iOS is same like others. You can follow the below guide to upgrade the iOS of your router which will have the updated CME.
http://www.cisco.com/c/en/us/support/docs/routers/3800-series-integrated-services-routers/49044-sw-upgrade-proc-ram.html
Salam mudasserilyas,
thank you for your reply and and your collaboration.
the problem is resolved.
Best regards
Akram
Please let me know what steps you performed, so that other users can also benefit from your experience.
Was it iOS upgrade?
it's ok with pleasure ,
I used version ''isr4300-universalk9.03.16.05.S.155-3.S5-ext.SPA.bin""
and firmware used for phones are 10.3.1
finally i changed ,and create this configuration :
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711alaw
h323
call preserve
sip
registrar server expires max 120 min 60
reset timer expires 183
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 clear-channel
voice register session-server 1
keepalive 60
register-id Router
cti-aware
can you find in attachement the global configuration.
Best regards
Akram
Ramadan moubarak for you :)
Suresh Hudda
Can you please attach o/p of "show voice register global", and please take these logs during issue "debug ccsip message", "debug ccsip error" & "debug voice register events" and attach here.
I would upgrade the cme/ios version on router to latest available version if not done yet.
Suresh
Thank you Surech for your reply
when i will collect this files i come back to you
Best regards
