HI,
You can use the CET tool (not advisible only TAC uses it) to make it a fresh install, and use Administrator\ciscocisco to login and select the UCCX Admin user one more time.
If its a Windows based (UCCX 7.0 or earlier versions) , follow the below procedure for using the CET tool.
- Start CET.
- Go to Start>Run and type "cet" or run cet.bat in the "C:\Program Files\wfavvid" directory
- Select "com.cisco.crs.cluster.config.AppAdminSetupConfig" from the config object type tree and double click on the row at the right pane.
- Select the "com.cisco.crs.cluster.config.AppAdminSetupConfig" tab
- Change the Setup State from to "FRESH_INSTALL".
- Restart the Node Manager services.
- After the Node Manager service loads. Launch the IE browser and browse to http:///Appadmin
- Login Administrator/ciscocisco credentials.
Hope this helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
