Community Helping Community
200
Beginner
CSF Device License
If i create a CSF device profile and leave the owner ID as anonymous will that consume a basic or enhanced license?
CUCM 10.5 PLM
Would i be better using extension mobility log out profile on the CSF or assigning an owner ID.
The user only has a softphone.
Adam
3 REPLIES 3
Rising star
Re: CSF Device License
As far as I know enhanced , it won’t be of any use to anyone if not assigned or associated . I can check in a bit .
It doesn’t support Extension Mobility so you cannot use it like you can with the phones set to anonymous
Hall of Fame Cisco Employee
Assigning a owner user ID is a mandatory step for Jabber so service profiles are found upon login, have you reviewed the Jabber configuration guide?
java
if this helps, please rate
Rising star
CSF does use the Enhanced tier.
Content for Community-Ad
FusionCharts will render here
