09-01-2014 09:10 AM - edited 03-16-2019 11:58 PM
Hello all
I have added a new CSF device for a CUCILync user. I have associated the correct end user with the device and configured the correct tftp details for my subscriber
Any ideas welcome
Simon
09-01-2014 10:26 AM
Are you able to login or are you getting any errors when you attempt to login from CUCILync?
What version of CUCILync are you using?
Chris
09-01-2014 11:47 AM
Hi Chris
I will need to check again in the morning but a I think the CUCILnyc manages to sign in ok....version.9.
Will let you know the full status in the morning
Simon
09-02-2014 12:37 AM
Hi Chris
Yes, I can sign in no problem but still not registering
Simon
09-02-2014 06:06 AM
Can you post the cucilync logs from local machine?
Chris
09-02-2014 09:14 AM
Hi Chris
I have checked in the CUCILync folder but cannot see any updated log files in there. Should I be looking elsewhere?
09-02-2014 04:34 AM
The exact version of CUCILync is 9.7.(3)
