12-06-2016 03:09 AM - edited 03-17-2019 08:52 AM
Guys,
I am getting issue in our call manager and ccx. CTI Route Point showingin IPv4 Address is none and is flapping. Sometimes i can see the ip address of uccx but suddenly it disappears and just "none" state. In none state we can recive calls, but during this period every 1 of 3 calls is getting busy trigger.
Did anybody experince suce issue?
Shahzad
12-06-2016 03:52 AM
What is the Common Device Configuration being used there in the CTI Route Point. Please make sure IP Addressing Mode is set to use IPv4 only in the Common Device Configuration profile that is being referenced by the CTI Route Point.
Deepak
12-06-2016 04:02 AM
Thanks Deepak.
Common Device Configurations were not there previously. I did configure them but still same behavior. Please confirm me there are same CDC is being used for the CTI ports as well. Do you want me to configure different CDC for CTI Route Point with IPv4 mode only in that?
12-06-2016 04:08 AM
Yes, please configure a CDC just with IPv4 mode and don't forget to restart CCX Engine afterwards.
Deepak
12-06-2016 06:38 AM
Has this problem just started happening?
Sounds to me as if there is an issue with UCCX or there is a connectivity issue between UCCX and CUCM.
Are UCCX and CUCM in the same building?
12-06-2016 07:51 AM
Hi batts,
They are in the same building. Cisco said the issue is regarding the host machine and that is not working properly with the NTP server. so NTP could be the issue.
