07-31-2012 07:36 AM - edited 03-16-2019 12:27 PM
I downloaded CTL Client for Windows 7 from CUCM and installed it on my WIn7 PC in order to configure Cluster Security Mode.
After successfully connecting to the Publisher using admin login & pwd, I select "set Cisco Unified CallManager Cluster to mixed mode".
I then receive a message asking me to insert a token, wich I do. But after clicking on ok", the message comes back, as it hasn't detect my token.
Windows does detect the token and install it correctly.
I also tried with the second token, and on a virtual machine running XP (with CTL client 4 XP)
Any idea?
CTL Client 5.0
CUCM 8.6
Win 7 SP 1
08-01-2012 06:51 AM
Update : Tried today with two other USB dongles and had no problem.
08-03-2012 07:21 AM
Dongles have been replaced and it is now working fine.
