CTL -- Migration & Update phones to another cluster
PC PC
Guys,
We have compagny  A  running CUCM 7.x on a cluster.
We have to migrate half of compagny A to another cluster at version 9.x
I was wondering if you have any advices to avoid CTL file issue ?
note : The new cluster have no user right now on it.
Jaime Valencia
Add the servers from the new cluster to the CTL file they're using right now.
Or disable security and migrate them, then re-enable on 9.X
java
if this helps, please rate
Jaime Valencia
java
Unfortunately, I don't have access to the actual server.
Do you think my best option is... when thoses phones will be on the other cluster, the new v9..  is to use Phoneview to delete CTL files ?
