01-10-2012 05:33 AM - edited 03-16-2019 08:54 AM
01-11-2012 10:37 AM
Hi Mike,
Sorry it took a while for a response! I had to search it out as it isn't an area that I'm well-versed in. Gen4 can replace Gen3. There is a minimum CTS software version requirement. We are searching out that information for you right now.
Julie Swenson
02-07-2012 09:39 AM
We recommend CTS1.8 software or later for the Gen4 displays on the CTS products. Thanks!
02-07-2012 09:55 AM
Sorry! The "Guest" reply above was my comment. The recommended software to run with the GEN4 displays on a CTS system is CTS1.8 software.
Thanks!
Julie
