CU Serviceability CDR report
chinpohpang851
I'm looking at the CDR report but can't understand all the details. where can i find supporting documents for the CDR report explanation?
I also noticed that if call wasn't answered, it is not logged in CDR. how can i monitor when call jump to another member in line group?
Jaime Valencia
Enable CDR to log calls with zero duration
CDR and CAR guides are here
https://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-callmanager/products-maintenance-guides-list.html
java
if this helps, please rate
Reza Mousavi
Just change the "CDR Log Calls with Zero Duration Flag" to True.
And for Cisco Call Detail Records Field Descriptions read the following doc
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/11_0_1/cdrdef/CUCM_BK_RFDE0054_00_cucm-cdr-administration-guide-1101/cisco_call_detail_records_field_descriptions.pdf
Also, I wrote the article about Cisco Call Manager Dashboard  maybe it's helpful!
