08-04-2021 10:02 AM
Hi All
I have a smilar question for CUAC 10.5.2 and CUCM 12.5 so my question that CUCM 12.5 is compatible CUAC 12.0.1 I can not see this information on the compability matrix ?
I can not see that cucm 12.5 and cuac 12.0.5 is compatible or not this document may required to update.
Solved! Go to Solution.
08-04-2021 10:07 AM
Refer below compatibility guide and be on the recommended versions.
08-04-2021 10:07 AM
08-04-2021 10:14 AM
Hİ Nithin
Thanks for your quick response, I was forget looking at this guide.
thanks
08-04-2021 10:44 AM
The CUACA RN as well as the design guide contain that information.
